Wishbone corrosion - Car Care / Restoration / Paint - TalkFord.com
Wishbone corrosion
3 replies to this topic
#1 joe101
joe101
  • 2 posts
Posted 10 June 2020 - 08:37 PM
I'm looking at buying a 2017 C-Max and had a look at the underside. The rear wishbones and subframe are a bit rusty (pic attached).
Is this normal for a three year old car? It's only done 16,000 miles.
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28199 posts
Posted 10 June 2020 - 10:35 PM
If your keeping the car for a long time then treat that and get it painted.
If your only keeping it a short time then its fine, let the next buyer sort it.
#3 joe101
joe101
  • 2 posts
Posted 11 June 2020 - 06:36 AM
Thanks.
Would you expect the seller to treat it before buying, or is it considered normal wear and tear?
#4 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28199 posts
Posted 11 June 2020 - 06:25 PM
Normal wear and tear. I would be suspicious if they had tarted it up.
Hiding crash damage or where its been grated over speed bumps etc.
I was under the dash of a MK3 Mondeo that was under 5 years old and the bar
that ran across the car has rust on it. Never been wet in that area so the bar must
have been poorly prepped when they fitted it.
