Engine shuddering when turning off - Diesel Engines (Mondeo Mk3) - TalkFord.com
shuddering shaking turning off
7 replies to this topic
#1 rtedy
rtedy
  • 2 posts
  • Vehicle Driven:Mondeo MK3
Posted 26 May 2020 - 08:13 PM
Hello,
my Mondeo 2004, 2.0 85kw shudders when I turn off the engine. Based on info I have found on internet, it looks like faulty anti shudder valve. I have trouble finding it, can anyone help me? Does this motor even have one?
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28314 posts
Posted 27 May 2020 - 10:14 AM
Worn engine mounts or lower engine/gearbox roll mount?
I would start there first. 16 years old they are probably the issue. Failing that start
on the injectors and fuel system in general.
Or DMF failing?
#3 rtedy
rtedy
  • 2 posts
Posted 11 July 2020 - 07:13 AM
I finally got to replace engine roll mount and it totally solved my problem. As you can see on the photo it was completely destroyed. Than you for you advice.
https://ibb.co/jDZ2DJG
Edited by rtedy, 11 July 2020 - 07:16 AM.
#4 DavieWeegie
DavieWeegie
    Mondeo Lover
  • 599 posts
  • Vehicle Driven:Mondeo ST TDCI 2005
  • Name:David
Posted 12 July 2020 - 12:22 AM
exact same happened to me, it had split identically to yours in the picture, once replaced all engine movement was back to normal and it even cured a long standing problem i had with 4th gear where it wouldnt engage fully, thought i was gonna need a new gearbox but turned out this torque restrictor caused all my problems, very common failure on the mk3.
Performance Blue Mondeo ST TDCI 2005
#5 Rekusu
Rekusu
  • 1867 posts
  • Vehicle Driven:Mk3 Mondeo, TDCI
Posted 12 July 2020 - 11:34 AM
To the best of my knowledge, mine does not yet need replacing.  However, as it is not so expensive, it is a job to consider.
Is there a good  quality make to buy, or will almost any (https://www.ebay.co....0IAAOSw-AFeaTSV)) do the job?
Toodle pip
Edited by Rekusu, 12 July 2020 - 11:42 AM.
What if the Hokey Cokey IS what it's all about?
#6 DavieWeegie
DavieWeegie
    Mondeo Lover
  • 599 posts
  • Name:David
Posted 12 July 2020 - 01:05 PM
DO NOT! buy one of them from Ebay, get a proper Ford one, I used one of them cheapies and it lasted a month and the front bush completely split apart like you see in rtedy's picture above.
#7 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28314 posts
Posted 12 July 2020 - 01:15 PM
Price them up at Ford or oddly Jaguar.  They used to be cheaper from Jaguar
dealers but still stamped Ford.
Just find an X-Type for sale and use that reg number when buying.
Cheap ones are junk, I have a brand new one that was part of a group buy on here
and it was splitting even when new. There were comments on the metal not being
as strong also.
This was less than a month old and straight from teh packaging unused, see the cracks forming.
#8 hardy1812
hardy1812
  • 384 posts
  • Vehicle Driven:Mondeo ST TDCi
  • Name:Ian
Posted 17 July 2020 - 04:57 AM
Can you buy poly bushes to fit into them ???
I’d rather replace with poly bush than buy a new one,, looked on powerflex and they don’t list one ??
Also tagged with one or more of these keywords: shuddering, shaking, turning off
