Rear fog light switch - Ford Escort Forums & Ford Orion Forums - TalkFord.com
3 replies to this topic
#1 Rockie
Rockie
  • 2 posts
  • Vehicle Driven:Escort
  • Name:David
Posted 23 February 2020 - 11:24 AM
98 escort rearfog light switch stays on when lights switched on any ideas
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29202 posts
Posted 23 February 2020 - 11:55 AM
Unplug the switch, do they go off?
Fitted any bulbs recently?  Not fitted a single filament bulb into a twin socket?
#3 Rockie
Rockie
  • 2 posts
  • Name:David
Posted 23 February 2020 - 12:40 PM
no bulbs been changed when I put my lights on the fog light rear comes on switch on dash board will not turn off stays light changed switch same problem ?
#4 turbopete1
turbopete1
    TF regular
  • 583 posts
  • Vehicle Driven:mk4 mondeo zetec
  • Name:Peter
Posted 23 February 2020 - 03:24 PM
sounds like its getting power from somewhere it shouldnt. id be tempted to pull the relay and see what happens. coulod be a relay fault. i cant remember which one it is though, but it does sound like its getting a power supply from somewhere so assuming the replacement switch was a known good unit, relay would be my next point to check (burnt contact shorting out/welded closed or similar)
a 98 will be the last of the escorts (mk6/7 depending on how you number them, if you call the mk5 facelift a mk5a or a mk6) which i dont remember having issues but mk5 escorts particularly had issues with water getting into the car and corroding the fusebox, but id say its VERY unlikely a mk7/6 (whichever you prefer) will have this issue.
