Fault Code Reader - Page 2 - Ford Galaxy Forum - TalkFord.com
Fault Code Reader
11 replies to this topic
#11 Russats
Russats
  • 16 posts
  • Vehicle Driven:Ford Galaxy Ghia 140
Posted 08 February 2020 - 09:48 PM
Quite a few fault codes.... I was hoping for dates and times. Lol would an intermittent fault not show up unless it was present at the time of the scan??
#12 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 27850 posts
Posted 09 February 2020 - 07:15 PM
All logged codes will show up.  There maybe codes that have reset themselves and do not get
logged after an engine restart or x number of engine restarts.
Some codes may vanish if the fault is no longer present.  Make a note of the current list and
then clear them all.  Start with the codes that return after starting the car.
Don't get caught in to the trap where a fault code means replace that part.  You need to think
to what can cause that code.
ie.. Fuel sensor out of range, dont assume its the sensor at fault. What can cause that?
Clogged fuel filter, pump pressure out of spec, fuel leak, injectors partially blocked or leaking
back too much fuel etc etc..
