If whatever is behind it is a relatively simple fix I want to do it as the burning oil stink is getting worse, especially after a thrashing
Steve.
Yesterday, 06:53 PM
Yesterday, 04:54 PM
Posted 02 February 2020 - 06:01 PM
Posted 18 February 2020 - 06:40 AM
On a diagram I found on fordwiki for the mk3 v6 about replacing the tensioner it says the top middle one (no. 2 by my reckoning) is the water pump. However I was told in one of my topics that the water pump's on the opposite side of the engine.
- Power steering pump pulley
- Water pump pulley
- Accessory drive belt
- Air conditioning (AC) compressor pulley
- Crankshaft pulley
- Accessory drive belt tensioner pulley
- Alternator pulley
- Accessory drive belt idler pulley
I'm going to get a haynes manual for my car soon so I'll have a look and see what they say. An alternative might be your power steering pump or a hose connected to is leaking under high pressure? I know when mine sprung a leak several years ago it stunk of burning oil, though that was because a hose round the back popped and pissed all the power steering fluid over the exhaust manifold.
Posted 18 February 2020 - 02:33 PM
Fiesta 1.0 ecoboost 2014
Posted 23 February 2020 - 12:37 PM
Explains why the diagram I found is wrong. It isn't, it's just for the 1.8/2.0l. Didn't even read the first paragraph. I can't delete/edit that post either for some stupid reason so that misinformation will now remain there forever more I guess. Whoops.
Posted 10 March 2020 - 11:02 PM
Thanks for your replies, I didn't get a notification so I've only found them by sticking my head in here to check
Hmm, the water pump still seems a likely candidate, the pully is in-between but slightly below the tops of the two cylinder banks but is the water pump lubricated, I don't understand an oil leak if it is the water pump?
I'm sure it's coming from the shaft behind said pully and not being flung up, the pattern is all wrong and nothing but the bottom side of the pully shafts housing and a straight path down the side of the block to the sump has any oil on it.
I'll try and grab a photo of it tomorrow, that would help a lot more lol.
I've driven a 2.5L V6 mk3 for the last 16 odd years but I have never EVER had a single problem with anything to do with the engine on ether of the two I've owned despite them being driven like they are stolen, apart from the y pipe flexy joint and the standard stuff like bushes and brakes so I've never had any need to know what's what on the pully side of the engine till now.
Seriously, I've never even had to replace a belt, alternator or even a starter, my first was so dam reliable I was not buying anything but a direct replacement when the original was so tatty it just had to go lol.
Speaking of which, here's my first one, taken back in 2003 when it was just a couple of years old (it was a 2001) and only had 32,000 on the clock and was not beat up by the bad parking of my ex wife yet lol.
I like my current one but the old one really knew how to sparkle when it was clean
Edited by Steve_v6, 10 March 2020 - 11:06 PM.
Posted 11 March 2020 - 09:10 AM
Posted 11 March 2020 - 02:19 PM
Here's the pully where the oil is leaking from.
I'm hoping that a fix is relatively easy to do, I'm competent and do all my own work on cars and refuse to pay garages!
I'm not loosing crazy amounts of oil but it's traveling down the side of the block, onto the sump and then getting onto the hot exhaust and it absolutely stinks
Edited by Steve_v6, 11 March 2020 - 02:21 PM.
Posted 11 March 2020 - 03:20 PM
Posted 11 March 2020 - 05:02 PM
Looks like the power steering pump pulley to me.
Sometimes I wake up grumpy. Sometimes I let her sleep in.
Posted 11 March 2020 - 11:16 PM
Over 10 yrs ago i had a slight oil leak that side upto top of engine,
resealed oil sump gasket and not done anything else,the leak on
the side of engine has gone.
Could the pulleys splash oil up the engine.
Edited by mondy zetecs, 11 March 2020 - 11:17 PM.
