Steering was stiff - Suspension / Wheels / Brakes / Steering (Mk3 Mondeo) - TalkFord.com
Steering was stiff
4 replies to this topic
#1 chrisland
chrisland
  • 43 posts
  • Vehicle Driven:Ford Mondeo
  • Name:Christopher
Posted 07 January 2020 - 07:10 AM
A couple of weeks ago I went out in my Mondeo, as I got to the end of the road to turn left I found the steering to suddenly be very stiff. Turning right had been fine. I carried on and didn`t notice anymore problems. This me a bit so I took it to my local garage for a check over. They couldn`t find a thing wrong. I left it with them again a week later expecting them to fit new top mounts, but they were not needed as everything was as it should be. I have had no more problems since the original occurrence and the car drives perfectly normal, even my wife says t is ok and she does 250 miles a week in it.
Any ideas what could have caused this? Would it be worth flushing the PAS system? Possible column UJ ( but why have I not experienced any more problems?) even the garage were baffled.
#2 Mondygeek
Mondygeek
    dont listen to me, you'll have horsepower and no money
  • 2967 posts
  • Name:Ben
Posted 07 January 2020 - 05:35 PM
Maybe there was air in system and it was just passing through the pump
  • chrisland likes this
#3 stevegti6
stevegti6
    Advanced Member
  • 44 posts
  • Vehicle Driven:mondeo tdci
  • Name:Steve cotterell
Posted 08 January 2020 - 10:33 AM
Try changing the power steering fluid I had the notchy steering issue which the mondeos suffer with. And after changing the fluid to the correct spec it’s as good as new. The stuff that came out was well passed it’s sell by date.
#4 chrisland
chrisland
  • 43 posts
  • Name:Christopher
Posted 14 January 2020 - 05:55 AM
Thank you for your feed back on the matter. I will change the fluid as it is a cheap option.
#5 chrisland
chrisland
  • 43 posts
  • Name:Christopher
Posted 14 February 2020 - 07:53 AM
An update to my steering problem. I withdrew some fluid from the reservoir and found it was like this black oil. So with the help of a good mate who had done a few of these, we bled the system with new fluid. All I can say is what a difference this has made. It is at least 95% better. I will do it again as any old crap left in the system will be in the new oil, so I will bleed it through at some point. All in all, a cheap remedy. Thanks for the advice.
