I recently changed the oil on my car and have a couple of questions.
How tight was your oil filter to remove, mine was ridiculously tight. Infact the guy at the parts department even told me it had to be that tight because of the vibrations causing them to come loose.
When I removed the undertray to access the sump there was some kind of rubber breather pipe just lay on top of the tray connected near the oil filter. The thing is though, because this pipe just lies on the tray, which is obviously lower than the pipe, it causes a kink in the pipe.
Should the other end be connected to somewhere else and has just fallen down ?
Has anyone seen this ?
I've got a picture that may help.
Edited by ericthecat, 17 September 2019 - 10:26 AM.
