Flexi downpipe - Exhausts / Induction (Mk3 Mondeo) - TalkFord.com
Flexi downpipe
17 replies to this topic
#1 Flynn50
Flynn50
  • 56 posts
  • Vehicle Driven:Mondeo Mk3 130 TDCi
  • Name:Andy Bell
Posted 15 June 2019 - 02:08 PM
My flexi downpipe has a couple of small holes in it and came up as an advisory on my last MOT.
I have seen a variety for sale considerably cheaper than the Ford part but have also seen some reviews where the pipe i/d on the replacement downpipe was smaller than the original causing a loss in power.
Can anyone recommend a replacement downpipe without this reduction in diameter?
Can the connecting bolts be re-used?
Thanks for any help.
Andy
Sent from my SM-G960F using Tapatalk
#2 raynkar
raynkar
    Dash cams, catch 'em out :)
  • 12924 posts
Posted 15 June 2019 - 06:32 PM
Are you looking for a whole exhaust section that matches the Ford item, or just a weld/clamp on flexi section?
#3 Flynn50
Flynn50
  • 56 posts
  • Name:Andy Bell
Posted 15 June 2019 - 06:41 PM
I was just looking to swap out the knackered section with the part that came up when I searched. I am not looking to chop and weld anything if that's what you mean
#4 Mondygeek
Mondygeek
    dont listen to me, you'll have horsepower and no money
  • 3191 posts
  • Name:Ben
Posted 15 June 2019 - 06:44 PM
Is it petrol or diesel? Unless the the inner diameter is massively different I can't see it causing any drop in performance
#5 raynkar
raynkar
  • 12924 posts
Posted 15 June 2019 - 07:56 PM
I was referring to this type of thing:
But as the section of pipe on the diesel is low in cost it’s not worth the effort.
This aftermarket pipe is only about a fiver more.
Even the genuine Ford item isn’t too bad. I initially thought of a clamp/weld in section as The front flexi sections for my mondy are both over £75.
#6 Flynn50
Flynn50
  • 56 posts
  • Name:Andy Bell
Posted 15 June 2019 - 08:20 PM
It's a diesel.
I see what you mean, I didn't realise you could get the flexi bit on it's own.
ll have to get underneath it and have a look to see if I can get away with just the flexi.
#7 nicam49
nicam49
  • Gold Member
  • 4271 posts
  • Name:Nick
Posted 15 June 2019 - 10:32 PM
I got mine from Ecp, but the one they supplied 1stly and 2ndly was too small diameter, also the gasket they stock is only for the smaller diameter version. I had to go to the Ford main dealer for the correct gasket, which they need the vin for. The 3rd version ECP supplied was the correct size, but the whole thing was very inconvenient and meant several journeys.
#8 Flynn50
Flynn50
  • 56 posts
  • Name:Andy Bell
Posted 16 June 2019 - 06:34 AM
It seems its a bit of a crap shoot as to whether you get the correct size.
it's
#9 nicam49
nicam49
  • Gold Member
  • 4271 posts
  • Name:Nick
Posted 16 June 2019 - 09:12 AM
Unless you buy it from Ford dealer. using you vin ensures you get the correct part.
You could, however, use www.catcar.info putting in your vin and seeing what the 7-digit code is, (finis code) then do an ebay search on Ford + code.
#10 Flynn50
Flynn50
  • 56 posts
  • Name:Andy Bell
Posted 16 June 2019 - 10:02 AM
I'll try that, thanks.
    Bing (1)
