2006 Ka, Cylinder 2 misfire but only occurs when starting car - Mechanical (Ka Mk1) - TalkFord.com
ignition spark plug misfire
2 replies to this topic
#1 curpha
curpha
  • 1 posts
  • Vehicle Driven:KA 2006
Posted 29 May 2019 - 06:42 PM
Hello everyone,
I own a Ford Ka 2006 1.3i (70hp). When I start the car, sometimes the engine will sound like there is bashing but could also be hard vibrations which vibrate across the car; if I continue driving an engine light appears and from my code reader, it says cylinder 2 misfire.
However, if I stop the engine and start it a couple of times, the issue can go away and then the car drives normally again.
I have recently installed new spark plugs and HT leads, aswell as a new battery. I took the spark plugs out today and they had a slight coating in grease or oil, making me believe the engine is running rich. But I have no idea what could cause this. Any help would be really appreicated!
Edited by curpha, 29 May 2019 - 06:43 PM.
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28991 posts
Posted 02 June 2019 - 08:32 PM
Covered on grease/oil on the pins or also on the shaft?
Oil seeping onto the plugs/leads and running down as you remove them?
Plugs gapped properly?  Coil issues?  Air leak?
#3 Squirt
Squirt
    I might like Fords
  • 1667 posts
Posted 21 February 2021 - 08:04 AM
If you inspect the spark plugs, can you see any black carbon lines down the ceramic white of the plug?
Blue Oval Vehicle Services
Cheltenham's Ford Specialist
www.blueovalvehicleservices.co.uk
Also tagged with one or more of these keywords: ignition, spark plug, misfire
