2.0 Duratec auto won't rev past about 4k rpm - Page 4 - 1.8L / 2.0L Duratec Petrol Engines (Mondeo Mk3) - TalkFord.com
33 replies to this topic
#31 Merstrand
Merstrand
  • 2 posts
  • Vehicle Driven:Mondeo Mk III
  • Name:Morten Merstrand
Posted 24 September 2020 - 04:49 PM
Did you ever find a solution ? My 2.0 Duratec is doing the same
#32 Communist
Communist
    Mk3 4 LYFE
  • 277 posts
  • Vehicle Driven:2005 Mondeo 1.8
  • Name:Karl Marx
Posted 24 September 2020 - 05:44 PM
I know this is an old thread but fuel pump + filter would be my first thought too. Seen this happen before.
#33 Merstrand
Merstrand
  • 2 posts
Posted 25 September 2020 - 09:20 AM
Just for info to all, my mondeo MkIII did the same no rev over 4000-4500 , no acceleration, engine knock and a strange engine noise.. I replaced mostly everything because of the knocking which mislead me alot.
I replaced Knock sensor, cam sensor, crank sensor, MAP sensor, ignition coil, plugs and cables, fuel pump, fuel filter and the timing chain.. Nothing helped at all ! The engine did precisely the same, then i took of the cat and the engine reved over 6500 like nothing.. Took out the core and it really looks normal but for some reason the air can't pass thru the cat.. Now the car finally runs again  ;)
#34 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28556 posts
Posted 25 September 2020 - 12:19 PM
Not seen that issue for a long time, I read about it somewhere and then at
work a few days later one of the lads had an issue where his Rover Tomcat
would not rev up, dropped the exhaust after work and the cat had collapsed
and blocked the exit pipe.
