Mondeo mk 5 pressure in coolant tank - Diesel Engines (Mk5 Mondeo) - TalkFord.com
mk5 mondeo
4 replies to this topic
#1 owen3515
owen3515
  • 9 posts
  • Vehicle Driven:mk4 titanium x
  • Name:owen
Posted 20 January 2019 - 08:20 PM
How's it going have a mk5 Mondeo 180ps 93000miles
Car is building excess pressure in the coolant tank this blowing out coolant
Changed the water pump ( found the original,unit was rubbing the block)
Replac d the thermostat unit as well
Also done a sniff test on the engine at hot and cold and no sign of head gasket issues
Has any one come across this problem
#2 bunkum
bunkum
  • 8 posts
  • Vehicle Driven:mondo
  • Name:Mick Flynn
Posted 20 May 2020 - 12:39 AM
hi Owen . im not sure of this but a sniff test only afaik  gives indication if coolant is leaking from the head of hoses on the engine outer parts but if the head gasket was leaking in to the inner cavitiea ie cylinder s or oil ports etc it would not necessarily show on a sniff test but you would need ot test the oil for water at the sump nut or it would possibly need a cylinder or block pressure test to acertain if the head was leaking .. also check the oil cooler unit . really a mechaics or dealershilps issue .. thei older mk3 s ofter sprung and oil cooler leak and oil would ingress into the cooannt tank as the oil pbessure it greater.
#3 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29158 posts
Posted 23 May 2020 - 10:12 AM
What else is the water cooling on that engine?  Turbo or Oil cooler?  EGR cooler?
Assuming its not overfilled or airlocks thats causing it to blow out.  New thermostat
sticking closed?
What temperature is the engine reaching and how quickly?  Use an OBD reader dont
trust the actual gauge.
#4 pthagonal
pthagonal
    Newbie
  • 186 posts
  • Vehicle Driven:Mk5 Mondeo Estate
Posted 23 May 2020 - 12:09 PM
Note 16 months from post #1 to #2
  • TreborB likes this
#5 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29158 posts
Posted 23 May 2020 - 03:17 PM
Thanks, I was talking to someone when posting and didn't notice the date.
