escoert mk6 diesel starting problems - Ford Escort Forums & Ford Orion Forums - TalkFord.com
1 reply to this topic
#1 thrash911
thrash911
  • 1 posts
  • Vehicle Driven:escort mk6 van
  • Name:michael
Posted 02 November 2018 - 05:10 PM
ok help needed here, my mk6 escort 55 diesel van (non turbo) snapped the timing belt a few weeks back, bought a second hand engine for it as it was cheap , guy said it was a good runner, long story short I have put a aftermarket pump solenoid in it to bypass the pats system I have power going to it, the glow plugs have power going to them but I cant get the starter to turn over, it will spin over if I cross the contacts with a screwdriver, there is no power going down the wire to the starter solenoid, the security light flashes on the dash but it flashes that fast I cant count the flashes, is the starter connected to the pats system, don't really want to swap the injection pump if there is a simple bypass, I have already removed the security cover on the pump .
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 29206 posts
Posted 03 November 2018 - 12:18 AM
I thought the pumps were coded not just the solenoid?
Yes the starter is enabled only after the correct key is used to start the car, fitting your
old pump should cure the problem.
Do the recon pumps come blank and code themselves into the system on first starting?
