W reg fiesta only blowing hot air - Ford Fiesta Mk4 / Mk5 Forum - (1995-2002) - TalkFord.com
1 reply to this topic
#1 Persia-Chris
Persia-Chris
    Advanced Member
  • 32 posts
  • Vehicle Driven:Mondeo mk3
  • Name:Chris
Posted 11 July 2018 - 03:16 PM
Hi
I have just got my mrs a “W” fiesta as a little run around and its only blowing hot air.
After a bit of research ive found that the heater control valve could be the problem. However ive just had a multi meter on the plug to make sure power was getting to it, but its showing 0v when the dial is either on hot or cold.
Does anyone have any ideas on what fuse (if any) supplies the hcv or any other possible cause as to no power going to it?
TIA
#2 johnyor
johnyor
  • 12 posts
Posted 14 September 2018 - 09:14 PM
It’s definitely heat control valve. Got third in my Fiesta :) not expensive part.
