Central locking multiplugs misbehaving - Electrical (Mk1/Mk2 Mondeo) - TalkFord.com
central locking multiplug bad contacts
3 replies to this topic
#1 Cbid
Cbid
    Advanced Member
  • 31 posts
  • Vehicle Driven:Mondeo Mk2 Ghia X V6
  • Name:Chris
Posted 14 June 2018 - 08:20 PM
Hi, I have 1999 mondeo ghia x.
Central locking works fine using fob.
But when using key in the door lock, central locking only works when it's really warm.
Took door card off and pulled the multiplug from the bottom of the door lock. Didn't look dirty however 20 mins with a dremel and electrical contact cleaner cleaning up the contacts, both male and female, and put it back together and everything works perfectly.
However a few days later it returns to its not working state.
Been through this process several times on both driver and passenger doors.
Always the same, works perfectly but only for a few days.
Am I missing something or doing something wrong.
It's not major but is very frustrating.
Any advise welcome
#2 Harkonnen
Harkonnen
  • 7 posts
  • Vehicle Driven:Mondeo mk2
  • Name:Erik
Posted 14 June 2018 - 08:27 PM
I have the same problem but only in the winter, it doesn't open any doors bellow like - 5 degrees Celsius.... I only have a key and not a remote. There should be a problem with the locking system (where you put the key in). There is no electrical problem, because you use the key fob and it opens the doors, so you need to check the door lock, unmount it, there should be some metal contacts that are dirty and that's why it won't open the car doors! Hope you understood what I wanted to say!
Sent from my WAS-LX1 using Tapatalk
#3 Cbid
Cbid
    Advanced Member
  • 31 posts
  • Name:Chris
Posted 15 June 2018 - 06:30 PM
OK thanks for that. Will have a look next time I'm in there.
Fingers crossed.
#4 Cbid
Cbid
    Advanced Member
  • 31 posts
  • Name:Chris
Posted 22 October 2018 - 05:53 PM
Been a while but recently spent some time fiddling with the lock based on what previous poster said.
I tried not to unmount the door lock itself as having changed one a few years ago I found the little clips and rods VERY fiddly so tried to bend a wd40 straw "round the back" and spray. This did nothing.
Last chance was to spray through the front of the lock with the door open. There are some small gaps where the catch sits. So emptied a lot of wd40 on a "hit and hope" plan.
One week later and the central locking is still off the key.
Maybe got lucky but thanks again for the heads up from previous poster
Also tagged with one or more of these keywords: central locking, multiplug, bad contacts
