mk4 rear dampers - Ford Fiesta Mk4 / Mk5 Forum - (1995-2002) - TalkFord.com
mk4 rear dampers
3 replies to this topic
#1 Bozzazzr600
Bozzazzr600
  • 3 posts
  • Vehicle Driven:Fiesta mk4
  • Name:Anthony Boswell
Posted 13 June 2018 - 08:17 PM
Hi all ,changed my dampers (2000 mk4 i think fiesta) compressed spring removed circlip, removed top rubber mount,removed spring , put all back onto new damper. Fed shock up into hole fixed bolt at bottom ,put on top cap and nylok nut in the boot . What stops the damper coming through the top cap.i cant see what locks the damper rod tk stop it just extending into the boot area, driving me mad .
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28716 posts
Posted 14 June 2018 - 12:11 AM
Single bot fixing on the top not the 3 bolt type?  The single bolt holds down the
retaining plate.
90% of the stress is pushing up against the bodywork so little stress actually
pulling the shock downwards.
#3 Bozzazzr600
Bozzazzr600
  • 3 posts
Posted 14 June 2018 - 10:18 AM
I see what your saying ,but i tighten the top nut it just pulls the damper rod through,nothing seems to stop the damper rod from pushing through,
Does the top nut compress the upper mount to hold it
#4 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28716 posts
Posted 14 June 2018 - 01:41 PM
Large rubber damper and cup on the underside prevent it pushing through.
