hi ppl i hope you can help me guys. im installing an android rear view mirror the thing is that i need to connect the two wires with fuse the yellow one needs continuous power and the red one needs power when you turn up the ignition so when i check the cabin fuse box then i found that there is only one fuse of 10a. by the way comparing the sticker of the fuses and the fuse box there are some fuses that was changed for one with more amperes probably done by the mechanic because i never touch any of the fuse box.
the question is can i change one of those 7.5a fuse with the 10a one that is attached to the wire and if you already know what fuse i could use for the interchange.
is a ford mondeo 1.8td of 1993
i hope is understandable
