Impact Wrench - Tools and Test/ Diagnostic equipment - TalkFord.com
Impact Wrench
15 replies to this topic
#1 Rekusu
Rekusu
  • 1683 posts
  • Vehicle Driven:Mk3 Mondeo, TDCI
Posted 22 March 2018 - 07:54 AM
What ho one and all,
I feel  like buying an impact wrench but don't know which one.  I will not be using it so much so don't plan to spend a lot.
However, I see the battery ones look good, but it seems to me, the battery could get in the way where access is restricted.  On the other hand, mains powered ones seem to be larger tools and would have the same issue.
Lidl have one appearing soon at a good price, but it is a larger mains powered.
Your thoughts would be much appreciated.
Thanks and toodle pip
Rex
What if the Hokey Cokey IS what it's all about?
#2 Lionian
Lionian
  • 43 posts
Posted 22 March 2018 - 06:31 PM
[quote name="Rekusu" post="3021226" timestamp="1521705289"]What ho one and all,
Thanks for the heads-up on the Lidl impact wrench, Rex. I bought one this afternoon. I would have preferred a cordless one but for the occasional removal of wheels and at just £30, I thought I’d take the plunge. Not used it yet. It comes with a 3-year warranty so the manufacturer must have some confidence in its product.
#3 Gary Price
Gary Price
    Clever cloggs
  • 1849 posts
  • Vehicle Driven:Mondeo Mk3 TDCi
  • Name:Gary Price
Posted 22 March 2018 - 06:37 PM
I have a compressor & air impact wrench, I don't tend to use it much, seems a lot of hassle for the time it saves.
Electric (mains) one sounds interesting. Probably better then batteery ones, batteeries usually flat when you need them.
#4 Mondygeek
Mondygeek
    dont listen to me, you'll have horsepower and no money
  • 2967 posts
  • Name:Ben
Posted 22 March 2018 - 07:19 PM
Same here thanks for the heads up I also went and bought one this afternoon, I plan on doing my crank pulley soon so should be ideal
#5 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 27847 posts
Posted 23 March 2018 - 02:01 PM
The clarke mains powered one is very powerful, but restricted to being near the mains.
I bought the cheaper 12v impact wrench from machine mart, its OK as long as you
do not need to put forward pressure into it. If you apply forward pressure then its rubbish.
It will whip a wheelnut off in seconds, but when it needed to press on to remove the splined
bolts from the rear bearing then it wouldnt spin fast enough. It needs an additional bearing
which they skimped on.
Opted for the Ryobi 18v impact wrench, i have a few One+ tools and it made sense, its powerful
but not put it through its paces yet.
If you have mains handy all the time then the clarke electric one would get my vote.
#6 nicam49
nicam49
  • Gold Member
  • 3785 posts
  • Name:Nick
Posted 29 March 2018 - 10:11 PM
I've got one of those impact wrenches you hit with a hammer, Toolstation <£10, been very useful for removing/loosening front strut pinch bolts and rear hub torx bolts. It's 1/2" square drive with a 3/8" hex adapter.
<p><p>nicam49 2002 Mondeo TDCi Ghia X Estate mk3 pre facelift Stardust Silver+Rust. STOP PRESS! Mot passed @308,000+ miles... keeping fingers well and truly crossed.
#7 Mondygeek
Mondygeek
  • 2967 posts
  • Name:Ben
Posted 29 March 2018 - 11:08 PM
I used my lidle impact gun on Tuesday to replace 2 rear springs on a Yaris. I couldn't fault it, whipped off the wheels effortlessly and no problems on seriously rusted shock bolts without using any lubricant, it tightens upto 100nm which is probably it's only downfall but nothing a socket and bar didn't sort. Good value for money so far it's certainly paid for itself already
Edited by Mondygeek, 29 March 2018 - 11:09 PM.
#8 Rekusu
Rekusu
  • 1683 posts
Posted 30 March 2018 - 06:35 AM
Thanks for the replies.  I did buy one but have yet to use it.
In the past, there have only been a few ocassions when it would have been useful for removing stubborn nuts.  But if my memory serves me correctly, I don't think I would have been able to get it into the access space.
At the price, it can sit in the garage until needed.
#9 Mondygeek
Mondygeek
  • 2967 posts
  • Name:Ben
Posted 30 March 2018 - 07:30 AM
It's always handy for taking wheels off, it only takes me 5 minutes to reel out the extension and saves my poor hands levering the bar for the wheel nuts. Thanks again for the heads up
#10 Rekusu
Rekusu
  • 1683 posts
Posted 30 March 2018 - 11:27 AM
Yep; I'll use it the next time for the wheel nuts.  At least it will save me having to rummage in the wheel well for the various bits and pieces.
Aslo, I can now pretend that I am an F1 wheel change mechanic!
