Mk4 & Mk4 Bits Clearout - Members Ebay Links - TalkFord.com
1 reply to this topic
#1 bigi
bigi
    Conversmod & Powermod UK Install & Support
  • 1289 posts
  • Vehicle Driven:Mondeo 59 TDCi Tit X
  • Name:Ian
Posted 17 January 2018 - 12:48 AM
Hi Guys
I've just had a big clearout of Mondy Mk3 and Mk4 bits and stuck them all on eBay.  Thought I'd list them to you guys here - obviously offers considered from forum members for multiple items etc.
Mondeo Mk3
Preheater https://www.ebay.co....E:L:LCA:GB:1123
Headlamp Washer Jets/Pump/Pipes/Covers  Kit https://www.ebay.co....E:L:LCA:GB:1123
Rear Subframe Poly Bushes https://www.ebay.co....E:L:LCA:GB:1123
Mondeo Mk4
ABS Pump https://www.ebay.co....E:L:LCA:GB:1123
Chrome Upper Grill https://www.ebay.co....E:L:LCA:GB:1123
Washer Bottle https://www.ebay.co....E:L:LCA:GB:1123
YAW Sensor https://www.ebay.co....E:L:LCA:GB:1123
Leather Steering Wheel https://www.ebay.co....E:L:LCA:GB:1123
Steering Wheel Controls https://www.ebay.co....E:L:LCA:GB:1123
Headlight Switch https://www.ebay.co....E:L:LCA:GB:1123
AFS Module https://www.ebay.co....E:L:LCA:GB:1123
AFS Headlights (PAIR) https://www.ebay.co....E:L:LCA:GB:1123
Bluetooth Module https://www.ebay.co....E:L:LCA:GB:1123
ConversMod and PowerMod UK installer.  Mileage correction, module recovery and Mod advice available via PM and forum.  Here to help!
#2 wellerbucklerfoxton
wellerbucklerfoxton
  • 8 posts
  • Vehicle Driven:mondeo 2.0 tdci mk4
  • Name:martin
Posted 01 February 2018 - 02:21 PM
HI Ian
Just replied via ebay ref the AFS Light set!, I need to remove my projectors to clean/refit but can I ask.........as soon as I started to loosen the first 8mm nut I tried doing it up again and panicked because it kept spinning? almost as if it needed something the other side of the threaded bolt to be held fast as its tightened?
how easy was it for you? any pointers would be much appreciated indeed
many thanks
martin
