2.0 tdci loss of power, engine malfunction warning. - Diesel Engines (Mk4 Mondeo) - TalkFord.com
5 replies to this topic
#1 Matthewrblack
Matthewrblack
  • 3 posts
  • Vehicle Driven:Mondeo mk4 2010
  • Name:Matthew
Posted 15 January 2018 - 08:58 AM
Morning folks, on friday on the way home from work (15 mile drive) the car pinged an engine malfunction light. Got home turned the car off and back on again fault gone. Took another drive later on and instant loss of power and suckibg noise from the engine bay. Saturday morning I read the codes and was given a p00bc.
Bought and fitted a new maf sensor and tightened up the air box hose as it looked loose.
Went for a drive same thing, engin light on, restart car light gone. Took the battery out when I got home and reconnected after a half hour.
Sunday car drove fine maybe 50 miles.
Today 8 miles into work engine fault shows. Engine off and on has no affect. No codes stored when I put the reader in. Got to work with reduced power. Car off and on again no malfunction warning.
Im thinking split turbo/ intercooler
Egr valve or inlet manifold gasket.
Any help would be much apreciated.
Matthew
Edited by Matthewrblack, 15 January 2018 - 09:09 AM.
#2 gaskell71
gaskell71
    Little Megger always willing to help.
  • 573 posts
  • Vehicle Driven:2008 Mondeo 2.0tdci
Posted 15 January 2018 - 03:22 PM
With a sucking sound a good bet would be the air intake hoses give them a good luck over for splits.
#3 Matthewrblack
Matthewrblack
  • 3 posts
  • Name:Matthew
Posted 15 January 2018 - 07:36 PM
Thanks for the reply. I should have it on a ramp on wed night to give the intercooler pipes a good going over.
#4 Matthewrblack
Matthewrblack
  • 3 posts
  • Name:Matthew
Posted 16 January 2018 - 09:11 AM
Got a new code this morning P00BD airflow too high.
#5 Archibald
Archibald
    Newbie
  • 235 posts
Posted 17 January 2018 - 07:12 PM
Is intake not cracked, including plastic pipe running under the engine?
Vacuum system checked and pipes connected to correct connectors?
Sent from my XT1650 using Tapatalk
#6 PMF
PMF
  • 9 posts
  • Name:Paul
Posted 15 September 2020 - 09:26 PM
Matthew
Did you get to the bottom of your problem Matthew ?
