Passenger door closed & stuck in double lock - Security / Safety (Mk3 Mondeo) - TalkFord.com
lock security door stuck
4 replies to this topic
#1 FullStackDev
FullStackDev
  • 7 posts
  • Vehicle Driven:Ford Mondeo MK3
  • Name:Bas
Posted 06 December 2017 - 04:46 PM
Hello friends,
I have the following issue: the front passenger door is closed and stuck in the double lock state. I cannot open the door from the inside, outside or with the remote.
I took of (broke off) the door card, so I have access to the lock mechanism from the inside. I have tried absolutely everything I can think of, but I cannot manage to open the door. I need this door open ASAP because my MOT failed because of the door not opening.
I can manage to get the door in the 'half-open' stage by pressing on the door 'hook' (which actually holds the door shut) with a screwdriver, but - because the lock is in double-lock - there's a steel safety pin directly below that hook, which prevents the hook from going down far enough to completely unlock, but allows it to go down far enough to get it in the half-open stage. This is the same stage you're in when you don't push a door completely shut.
I have tried pushing, pulling & rotating the moving part of the electric lock, but everything is completely stuck in it's current position.
I guess my question and last hope is whether any of you know how to open this lock from the inside. I tried taking photo's, but my camera for some reason fails to focus / expose correctly. If photo's are needed let me know, I'll give it a few more tries.
Many thanks!
#2 mondy zetecs
mondy zetecs
    Clever Clauggs
  • 3920 posts
  • Name:Harry
Posted 06 December 2017 - 09:17 PM
Only idea that comes to mind is feed external source of power to the lock
Fiesta 1.0 ecoboost 2014
#3 nicam49
nicam49
  • Gold Member
  • 4004 posts
  • Vehicle Driven:Mondeo mk3
  • Name:Nick
Posted 08 December 2017 - 06:09 PM
I wonder if you remove the fuse to the central locking circuits it'll disable the solenoid which could be holding the door lock shut.. worth trying.?
#4 siruncle
  • 18991 posts
Posted 09 December 2017 - 07:40 PM
I think the solenoid just moves a cog or something to the deadlock position, then that's it, powers down.
<p>From Rutland, Leicestershire or Northamptonshire? Join the Rutland Group, http://www.talkford....land-area-page/ Leicestershire, http://www.talkford....leicestershire/ or Northamptonshire, http://www.talkford....rthamptonshire/2000 (W) Mondeo Mk2 Ghia 2.0 Hatch in Stardust Silver, now has company, a 2000 (W) Transit Smiley :) 2.5di (ish), in diamond white, with a blue stripe. (pics coming soon). Also now got a
02 zetec-s 2.5 in Panther Black and an 05 Fiesta St150 in colorado red
This is Ford country, listen quietly and you can hear Vauxhalls rusting :)
#5 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28478 posts
Posted 09 December 2017 - 10:19 PM
Thought i had replied to this.. losing the plot :)
How did you deadlock it?  Whats the issue with the lock itself, are you sure its not actually
unlocked but the handle is not operating the lock to open the door?
