I did use my car just about everyday, now when I turn the key to start all I can hear is a relay click (elec arial I think) I've done all the usual
checks; starter/solenoid/battery/starter relay/ earth strap & connections all ok. Gearbox inhibitor switch ok There's 12v at the ignition switch
& at the starter relay (in the fusebox). I can start it with with a wire from solenoid to battery-but it runs unevenly-and stops. It's one of the last
mk2s off of the line registered August '85 (2.8 carb Ghia x auto) I've had two 'experts' look at it to no avail
