Revving problem - Ford Fiesta Mk4 / Mk5 Forum - (1995-2002) - TalkFord.com
Revving problem
2 replies to this topic
#1 944turbo
944turbo
  • 1 posts
  • Vehicle Driven:MK5 Fiesta
Posted 19 April 2017 - 05:08 PM
Hi can anyone give me some help or offer any advice please after owning a MK5 phase 1 zetec S for just over 4 years and never really having any problems with this car we have now sold it and taken on our sons MK5 1250 zetec and although it is in far better shape it is already causing a problem.
I will try to explain what it is doing but does seem to maybe be the idol control valve but not really sure as the car does not seem to do what people say this valve does when having problems with it.
So here goes
The car ticks over lovely but as you drive off and you have gained in rev's then go to change gear the rev's stay there but if you keep the clutch pedal down before changing gear for a few seconds the rev's drop back down again,this happens every time you go to change gear come up to a junction or stop then the car ticks over lovely again.It is just a bit annoying when doing town work hope this all makes sense any idea's please what is causing this please or is this how it should be but have never driven a car before that does this and it is spoiling the driving of the car for me,I am sure the car did not do this when my son first bought the car but due to never really driving it while he owned it I cannot remember if it did or not.
Many thanks
#2 siruncle
  • 18998 posts
Posted 20 April 2017 - 09:17 PM
It is possible to give them a clean out with spray carb cleaner or something like that, sometimes this will cure it. Otherwise, there are usually plenty in breakers yards, should you wish to try a different one.
Check all the pipework between the air filter and throttle body are secure and not split or leaking. The air is measured, so if leaking the measurement will be inaccurate.
Same for the little vacuum pipes.
  • 944turbo likes this
#3 eagle_1313
eagle_1313
  • 1 posts
  • Vehicle Driven:Fiest MK5 1.25 16v
Posted 22 December 2019 - 10:46 AM
I had this problem... solution was: under the engine (I had LH fiesta), front side, you have some wires (i thing from aircon) that goes up to connector, black and white. One of them is probably broken. After I fix this, revving problems ended.
