I've got a 2008 Mondeo and just noticed that the a/c is not working. I've read the air con explanation below and sussed that in my case it's probably the seals gone dry and air loss due to not being used much over the last 6 or so months. 1) How can I check out if its the seals? 2) Can top up kits be purchased readily for DIY top up, if not 3)Can anyone recommend a company that they have used to fix seals / top up for me?
Locopella has posted in Engine malfunction/won't start in Diesel Engines (Mk4 Mondeo).
Today, 04:59 PM
PURPLE_2L_LX has posted in Have you modified your instrument cluster? LEDs etc. in Electrical (Mk3 Mondeo).
Today, 04:28 PM
mondy zetecs has posted in What did you do with your Mondeo today in Mondeo Mk3 General Discussion .
Today, 04:18 PM
mondy zetecs has posted in Waaaaa brake pedal hit the floor at 60mph 😂 in Suspension / Wheels / Brakes / Steering (Mk3 Mondeo).
Today, 04:08 PM
tombchasser has posted in What do you really dislike about the Mk5 Mondeo? in Mondeo Mk5 General Discussions.
Today, 03:12 PM
Today, 02:20 PM
twincarbs has posted in Stiff gear selection (1st & 2nd) first thing. ST TDCI in Transmission / Drivetrain (Mondeo Mk3).
Today, 01:51 PM
idiot's guide to air conditioning
Started by
, Jul 12 2005 01:18 PM
62 replies to this topic
#61
Posted 25 March 2012 - 04:33 PM
#62
Posted 25 March 2012 - 04:44 PM
i wouldn't use the diy top up kits personally, if you were to do something wrong, you could end up with serious injuries, this is best left to the experts, i believe this time of year places like kwikfit are cheaper than in the summer... You will get a a/c system test and a refill for your money. http://www.kwik-fit....d-servicing.asp
<p><p>From Rutland, Leicestershire or Northamptonshire? Join the Rutland Group, http://www.talkford....land-area-page/ Leicestershire, http://www.talkford....leicestershire/ or Northamptonshire, http://www.talkford....rthamptonshire/2000 (W) Mondeo Mk2 Ghia 2.0 Hatch in Stardust Silver, now has company, a 2000 (W) Transit Smiley
2.5di (ish), in diamond white, with a blue stripe. (pics coming soon). Also 05 Fiesta St150 in colorado red. This is Ford country, listen quietly and you can hear Vauxhalls rusting
#63
Posted 14 July 2013 - 08:40 PM
Just in case anyone's still using this 35 bar is approx 515 psi and a pipe would of blown off by this point. The hp switch cut out is nearer 22 bar approx and the system low side runs at approx 2 bar when on use and 6-7 bar when standing. The Lp switch cutout would be around 10 15 psi ( 1 bar) approx, good guide just a little out on the readings.
