Fiesta mk3 swaying under braking - Ford Fiesta Mk1 / Mk2 / Mk3 Forum - (1976-1995) - TalkFord.com
4 replies to this topic
#1 Prickly_buzz
Prickly_buzz
  • 18 posts
  • Vehicle Driven:Focus MK1
  • Name:Bill
Posted 09 February 2016 - 06:56 PM
My old Mk3 fiesta 1300 sways to the left then the right when I apply the brakes, it's more obvious with speed.
I've replaced both rear shocks because they had had it, and both front lower arms (one more recently and the other around 1,500 miles ago).
I have tested the brake balance on a brake tester and made sure all the wheels spin freely I.e no brakes binding on.
Any ideas??
#2 turbopete1
turbopete1
    TF regular
  • 577 posts
  • Vehicle Driven:mk4 mondeo zetec
  • Name:Peter
Posted 09 February 2016 - 08:16 PM
assuming no accident damage (ie its started a while after you got the car) id be looking at tyre pressures, tyre SIZES (fitting 185/55x14s onto a diesel engined car did odd things to the handling - just trust me on that!!! as can odd sized tyres on the same axle - again speaking from experience!) then id be looking towards the front shocks, then after that its looking like rear axle bushes etc.
tyre pressures would definitely be my first check as i remember mine (pre bigger wheels) did something similar when the tyres were low but didnt look like they were. its also cheaper than a pair of front shocks, which would be next in line!
Edited by turbopete1, 09 February 2016 - 08:17 PM.
  • gotta.turbo.it likes this
#3 gotta.turbo.it
gotta.turbo.it
  • 392 posts
  • Vehicle Driven:Ford Mondeo ST220
Posted 09 February 2016 - 08:32 PM
As above. First I'd check tyres are all same size and correctly inflated. Then I'd get a 4 wheel alignment done. Then I'd be looking at the rear trailing arm bushes.
#4 Prickly_buzz
Prickly_buzz
  • 18 posts
  • Name:Bill
Posted 09 February 2016 - 09:01 PM
Cheers guys, I forgot to mention something which your posts reminded me of.
The car was perfectly fine until I took it off the road for around 2 months, before I put it back on the road I replaced all four tyres with cheap winter tyres, all the pressures are the same and it's the original size, think this could have a bearing on it?
#5 scottybo
scottybo
    TF regular
  • 624 posts
  • Vehicle Driven:ford escort mk6
  • Name:scott walker
Posted 10 February 2016 - 02:28 PM
maybe a braking issue, seized or sticky caliper maybe
