Heated/Cooled Seats - Interior / Exterior (Mk3 Mondeo) - TalkFord.com
Heated/Cooled Seats
87 replies to this topic
#1 SNO BATT
SNO BATT
  • 155 posts
Posted 21 January 2016 - 02:18 PM
Hi peeps!
After a bit of information if I can please guys! I have a 2003 Ghia hatchback and I have located some heated and cooled seats from a 2004 vehicle. Will my car have all he wiring in situ or will I need the full loom to go with the seats?
Paul
#2 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28086 posts
Posted 21 January 2016 - 10:14 PM
Pot luck on whether the wiring is there or not.
#3 iamzod
iamzod
  • 92 posts
  • Vehicle Driven:Mondeo ST220
Posted 23 January 2016 - 01:05 AM
Get your coin holder out and check for the connector clipped to the back of it, there should also be a relay holder up the back of the fusebox behind the glovebox, it's brown & roughly inline with the blue & brown ones for the power fold mirrors & headlight washers.
I'd post pics but every time i try it deletes my post for some reason.
My 53 plate LX was already wired up for them.
Edited by iamzod, 23 January 2016 - 01:06 AM.
#4 iamzod
iamzod
  • 92 posts
Posted 23 January 2016 - 01:52 AM
Pic attached if it works.
#5 SNO BATT
SNO BATT
  • 155 posts
Posted 23 January 2016 - 05:20 PM
I've looked today, on the back of the pocket (between the cup holder and boot release switch) there was a 6 pin connector attached. Also behind the little glovebox by the drivers knee there was a large blue plug which from what I have seen is something to do with it. Therefore can I assume that everythin I need is there?
#6 iamzod
iamzod
  • 92 posts
Posted 25 January 2016 - 11:42 PM
It's not blue it's brown, the blue one is for headlight washers, the one you need is behind that in an upright position. I had to stick my phone up the back of the fusebox with the camera recording to find mine, you can't see it from looking inside the glove box hole.
#7 iamzod
iamzod
  • 92 posts
Posted 25 January 2016 - 11:46 PM
http://smg.photobuck...gjlpta.jpg.html
The above is a link to a picture of mine as this forum won't let me post images.
#8 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28086 posts
Posted 26 January 2016 - 04:30 AM
Forum should allow images unless they are too large. You may need to shrink them
down a bit.
I use  Paint.net its free and ideal for resizing the odd image. If you need to resize lots
then Irfan is the way to go.
#9 SNO BATT
SNO BATT
  • 155 posts
Posted 26 January 2016 - 12:06 PM
So even if I have the 6 pin connector with wires coming off on the back of the little coin tray on the centre console I still have not have the wiring in place?
#10 raynkar
raynkar
    Dash cams, catch 'em out :)
  • 12291 posts
Posted 26 January 2016 - 03:00 PM
Hi peeps!
Paul
The most important thing is that the seats you want to fit are facelift seats. Your car is a 2003, so could be pre facelift OR facelift. If your car is a facelift car with a rectangular LCD heater display life will be much easier. If your car is a pre facelift with three round controls for the heating them life gets more complex.
Facelift cars had variable heating for the seats, and will be wired (and loom plugged) for that. Pre facelift cars had on/off heated seats and so worked in a different way. Even the way the heated seat switch is fixed to the rear of the fascia is different pre facelift to facelift.
