ul9601 has posted in What did you do with your Mondeo today in Mondeo Mk3 General Discussion .
Yesterday, 10:49 PM
Leelow710 has started Scorpio aircon in Ford Granada Forums & Ford Scorpio Forums.
Yesterday, 10:38 PM
pthagonal has posted in Door mirror connectors in Interior / Exterior (Mk5 Mondeo) .
Yesterday, 08:41 PM
Andrew54 has started Door mirror connectors in Interior / Exterior (Mk5 Mondeo) .
Yesterday, 08:29 PM
Mark M has posted in Aftermarket DAB in Android head unit in In-Car Entertainment (Mk4 Mondeo).
Yesterday, 08:21 PM
Are the LED adaptive headlights supposed to be so bright ?
Started by
xyzMk5
, Oct 02 2015 09:15 PM
94 replies to this topic
#71
Posted 07 November 2015 - 05:03 PM
Annoyingly, I have just bought mine and keep getting flashed when in LHT.
64 Plate 2.0 (180bhp) Manual, diesel. Ruby Red titanium X Wagon. 112,000 miles.
#72
Posted 07 November 2015 - 05:57 PM
Hi st driver.
We all had that so it is important to have them adjusted
correctly while on the LHT selection. You will also get more
from your dipped lights in regards to road coverage.
Titanium+, 2.0 Lt.,150 bhp, Frozen White,
Partial leather, 6 speed manual,
Auto park assist, Privacy glass.
Titaniumx pack, (Irl version: Led lights
Electric hatch), Full spare,
#73
Posted 07 November 2015 - 06:06 PM
Yeah I shall pop into Ford at some point.
#74
Posted 07 November 2015 - 06:07 PM
If you are in the UK the setting should be "left hand traffic" as in the traffic drives on the left and when on the continent you should chug to " right hand traffic" as in traffic travels on the right when doing this it lowers the aim of the beam it does not change the direction of the "kick" of the beam.
#75
Posted 07 November 2015 - 06:24 PM
Yeah I understand all that. Seems some Ford dealers don't from what I've read here. Anyway, when I picked my car up setting was in RHT, previously a Ford management car. I set it to LHT after reading here and was flashed a lot this morning. I'm not holding out much hope with my local dealer as they have in the past been pretty useless. Unfortunately, the much better local dealer has now closed down. Will see what happens anyway.
#76
Posted 08 November 2015 - 04:21 PM
The early cars such as mine were set to RHT and lights statically adjusted in this setting - this means they will be wrong in LHT unless you get them re-aligned. It really is DIYable with a white garage door and level surface - just a single allen key / screwdriver to adjust each side. If you go to the dealer set it to LHT and ask them to check the beam alignment - don't let them change it back to RHT
#77
Posted 08 November 2015 - 04:25 PM
@ Woz099, Gregs24 - I understand your comments and reservations and I dont disagree with anything you are saying, but having sat with my Ford dealer and spoken to Ford technical directly with the dealer as well the RHT option is apparently the correct one for UK setups.
I still have my reservations, but my lights (set in RHT mode) seem to be much more effective now that they have been aligned properly. Plenty of light on the road ahead, lights up the verge on the left hand side but no-one coming the opposite direction is getting blinded - I've not been flashed once since they've been adjusted.
Still not sure what the correct setting is but as Gregs24 says if you are not travelling outside of the UK, then you should be able to get away with setting them left or right and adjusting them yourself against a garage door - of course MOT test time will come round eventually and it will be interesting to see what happens then!
#78
Posted 08 November 2015 - 07:37 PM
I have to say, I (as stated above) am convinced LHT is the correct setting. Having turned a Ford service manager inside out before when I asked him to explain what a 'Newton Metre' was I have no confidence they know. There has been various opinions on here and the jury remains unconvinced; some think LHT others RHT.
Odd though, those choosing RHT have to have lights adjusted; I have LHT set, haven't had anything adjusted and I have never been flashed! Oh, and I can see the road perfectly in all conditions when lights are on!
Mk5 Titanium X, 2.0 TDCI (180) +
Parking Assist Front/Rear Camera,
Keyless Entry,
Sports Suspension.
#79
Posted 08 November 2015 - 08:07 PM
Wouldn't have mattered which way I went mine would have needed adjusting no matter what. Setting mine to LHT before it went into the garage blinded every driver coming towards me - was getting flashed 3 or 4 times on a 12 min journey from station to home.
Clearly a configuration issue and a lot seems to be dependant on when your car was built.
I agree with you Woz that dealers usually can't tell their a*** from their elbow, but I would like to think that Ford technical have a bit more of a handle on situations such as these especially when they say they have had several calls about this particular issue which is what the chap said to me and my local dealer when we called.
Not sure we can get a straight answer on this one so it may well be a case of everyone dealing with it themselves to their own satisfaction. It's an easy adjustment with a screwdriver or Allen key whatever the case.
#80
Posted 09 November 2015 - 08:38 AM
Amm, I was on the phone with Ford support as well. They told me LHT is the right setting.
You were receiving flashes on LHT, because LHT was too high.
When lht is set correctly, switching to RHT lowers the beam in order not to blind oncoming traffic in continent.
When you drive with right hight @ rht, your beam is too high for lht.
That's my understanding
