Well, that is interesting. Just had few emails with my dealer. Here's some feedback:
Hi Simonas
My Ford contact has confirmed the positioning of the subwoofer to be correct and as per the image. But they are concealed on the vehicle, so not visible.
And yes, the lights will adjust on RHT, and the wipers will stop mid way if turned off mid operation. So you would need to allow time to fully drop to the starting position.
Hi,
So just to confirm regarding the lights:
· When I set to RHT while I am in UK – Lights will be pointed down, in order not no blind the upcoming traffic
· If I am in Calais and set the lights to the RHT – the height will be correct. However it should be lowered on LHT setting
Is this correct?
Simonas
Hi
Yes,
When in the UK on RHT the car won’t be picking up the correct surroundings, as you’ll be on the left, where as in Calais, you’ll be on the right, so will correct accordingly
So, it has to auto correct the height.
