Climatronic ventilation problem - Air-Con / Heating (Mk3 Mondeo) - TalkFord.com
6 replies to this topic
#1 [email protected]
[email protected]
  • 4 posts
  • Vehicle Driven:Ford Mondeo
  • Name:Lukasz
Posted 17 September 2015 - 11:52 AM
Hello.
I have a Ford Mondeo 2005 2.0 petrol.
I am have problems with ventilation inside the car.
For a long time the blower doesn't work when I switch on the clima control panel button to window blow. For a while I could force it to work by playing with the other two buttoms to select blow on face or feet. When I did that i could hear a mechanical sound like the ducts suddenly opened and the blower worked on the window. I have tried to diagnose the Climatronic system but it shows no error.
Anyone have an idea what is wrong ?
Best regards
Lukasz
Denmark
#2 RB2004
RB2004
  • 1481 posts
Posted 17 September 2015 - 12:17 PM
Broken flap inside heater box... Very common problem flap under €20 from ford
#3 [email protected]
[email protected]
  • 4 posts
  • Name:Lukasz
Posted 17 September 2015 - 03:25 PM
Thanks a lot for the response :D
But do you know where this heater box is located ?
#4 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28319 posts
Posted 17 September 2015 - 05:21 PM
Remove the trim panels to the centre console and you will see the pipework.
The panels are to the left and right of your knees when sitting in the front.
#5 [email protected]
[email protected]
  • 4 posts
  • Name:Lukasz
Posted 18 September 2015 - 06:34 PM
Ok but will i then be able do change the flaps ?
#6 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28319 posts
Posted 18 September 2015 - 08:37 PM
They may just need unsticking.
#7 RB2004
RB2004
  • 1481 posts
Posted 18 September 2015 - 09:35 PM
They normally snap not stick end breaks off where the servo motor engages.
To change flap if it has broken us a dashboard and heater box out job :)
