Water in the electrics? - Electrical (Mk4 Mondeo) - TalkFord.com
navigation low battery warning light
8 replies to this topic
#1 Pigfeet
Pigfeet
  • 17 posts
  • Vehicle Driven:Mk 3 Focus
  • Name:Martin
Posted 02 August 2015 - 12:42 PM
Dec 2014 Mk4 1.6 Dti Mondeo.  Yesterday I drove on a motorway in the rain to the supermarket and all was well, however when I got back into the car the Navigation had a blue screen and the little red pointer but no map, when I looked at the number of satellites it showed zero, and the message came up, something along the lines of make sure you are on a digitised road.  I tried restarting both it and the engine and made sure I was on a "digitised road" but, still navigation not working.  In addition the battery warning light came on with the message "low Battery", so two possibly associated electrical problems.  From the information I have seen on this and other sites, it appears to point towards damp getting into the electrics.  However, this morning the navigation and the battery warning have both resolved themselves, so it really does point at water getting into the circuits, I have looked under the bonnet but I cannot see any water around the fuses, etc,
Nan anyone tell me where is the most likely place where water getting in could cause the problems please?  Thanks in advance.
#2 mondeoman1987
mondeoman1987
  • 303 posts
Posted 03 August 2015 - 09:39 PM
Ariel base on the roof is where you want to be looking, it seems to be a common issue with some of the GPS Ariel bases unfortunately the only cure would be to get a new base as this is where the GPS receiver is housed
Good luck
  • Pigfeet likes this
#3 apollogary
apollogary
  • Gold Member
  • 1543 posts
  • Vehicle Driven:Mondeo
  • Name:Gary
Posted 03 August 2015 - 10:00 PM
Good luck
On a 2014 mondeo, it won't have a roof mounted aerial. Its on the windscreen behind the rain sensor cover.
If it came up with "low battery" and the engine was off, That's quite common and probably nothing to worry about. The battery monitoring is very sensitive. its possible your battery is on its way out, but unless it starts happening every day, I would ignore it. Hopefully the sat nav problem was just a blip
2008 2.0 TDCI Ghia Auto in Kelp
18" alloys, full biscuit leather,8 way electric climate seats, sunroof, NX nav, voice, keyless start, F & R PDC, TPMS, privacy glass
Mods.
Facelift convers+. Rear door roller blinds. Rear footwell lights. Rear Ambient lighting. USB, bluetooth & BT streaming. Memory drivers seat and mirrors. Auto folding mirrors with indicators. Door warning lights front and rear. Variable heated rear seats. PTC electric heater. Facelift front and rear bumpers and bonnet with DRLs and  headlight washers. Facelift tailgate and rear LED lights.
Keyless Entry. Power child locks, Cooled glove box, Air Quality Sensor, Facelift MCA2 with 9 speakers, DAB and Ford rear view camera. Facelift upper and centre console trims and upper door panel trims in walnut.
Adaptive Cruise Control, Forward Alert & Hill Launch Assist. Xenon Lights. Interactive Vehicle Dynamic Control. Electric Park Brake, Rear Seat Entertainment, 13 pin Detachable Tow Bar and Module
Photos in Gallery
#4 Pigfeet
Pigfeet
  • 17 posts
  • Name:Martin
Posted 04 August 2015 - 10:48 AM
Thank you both for your replies, and yes, there is no external aerial on these later models, so there must be another reason for the navigation problem, I need to do a drive in rain and see if it happens again.  Thanks for putting my mind at rest on the low battery warming, it was with the ignition on but the engine off.  Thanks to you both for taking the time to reply, much appreciated.
#5 craigy02
craigy02
    TF regular
  • 627 posts
  • Vehicle Driven:mondeo titanium x
  • Name:craig
Posted 04 August 2015 - 03:20 PM
I have a fx sat nav and have had same problems as yours map showing just the pointer and showing zero sats and make sure you are on a digitised road
after moving the gps slightly it picks the sats back up
petrol ford mondeo mk4 2.0 titanium x 57 plate
#6 Pigfeet
Pigfeet
  • 17 posts
  • Name:Martin
Posted 04 August 2015 - 06:45 PM
Hi, thanks for your reply, yes I am on digitised roads, if I am not on a digitised road the map still shows on the screen, the difference with the problem I had is that the screen was totally blue with just the red pointer, just like the dreaded screen of death you get on a computer.
#7 craigy02
craigy02
    TF regular
  • 627 posts
  • Name:craig
Posted 05 August 2015 - 06:51 AM
sorry I meant to put that's what mine comes up with about (digitised roads) nothing there but a pointer
playing with the gps solved this problem but now and again it still does this
Edited by craigy02, 05 August 2015 - 06:55 AM.
#8 Pigfeet
Pigfeet
  • 17 posts
  • Name:Martin
Posted 05 August 2015 - 08:29 AM
Thanks for that, when you say you play with the GPS, what do you actually do please that brings it to life?  When mine went off I did turn it and the engine on and off several times, but without any result.
#9 craigy02
craigy02
    TF regular
  • 627 posts
  • Name:craig
Posted 05 August 2015 - 12:47 PM
I had fitted my stereo myself so the gps I have sitting on the dash near the passenger side
I was going to put it in the pillar out of the way glad I didn't
just moving this slightly brings back the sats (as in info it states zero)and also bringing the screen back why this does this I don't know
 apollogary says yours is behind the rain sensor so worth having a look and see if you can move it and also making sure the connection behind your stereo is secure
Also tagged with one or more of these keywords: navigation, low battery warning light
