Wiring diagram for mk2 Fiesta - Ford Fiesta Mk1 / Mk2 / Mk3 Forum - (1976-1995) - TalkFord.com
2 replies to this topic
#1 mcbulla
mcbulla
  • 2 posts
  • Vehicle Driven:Ford Fiesta mk2 1988
Posted 23 May 2015 - 04:33 PM
Does anyone have a wiring diagram for a 1988 fiesta? Im not getting any power to the ignition switch or the fusebox, nothing happens when you turn the key. Hopefully i would be able to find where the problem is if i could get my hands on one.
#2 mcbulla
mcbulla
  • 2 posts
Posted 24 May 2015 - 07:52 AM
The car works fine if i put a cable from the battery on the red cable at the ignition switch. So does anyone know where the red cable comes from? so that i can replace it.
#3 lee25
lee25
  • 62 posts
Posted 24 October 2015 - 10:29 PM
have a look next to starter motor there should be a thin black wire attached to the terminal with the thick red that comes from the battery, that should be your problem
1966
Edited by lee25, 24 October 2015 - 10:29 PM.
