Electric auxiliary heater! - Page 7 - Diesel Engines (Mondeo Mk3) - TalkFord.com
69 replies to this topic
#61 oldbod
oldbod
  • 5525 posts
  • Vehicle Driven:Mondeo 2002 TDCi 130
  • Name:Alan Severne
Posted 27 January 2015 - 05:31 AM
Sorry Aaron - wasnt very clear i know. You said it warmed up 3 minutes quicker than normal, wondered if normally took 15 mins say and with heater on it was say 12, or maybe normally 7 min and with heaters on 4 say. You covered it nicely for me last post As you said, as long as everything is working properly, they warm up nice and quickly compared with some. That heated up to full temp in a mile is better than i've had in winter nd probably shows I need to recheck things. Actually feels slower to warm up now than when I had the main stat out. Still much faster than vw...but many vw have fbh - lovely...
Or not use hfw/hrw so much.
Good luck with the Passat. Which engine does your new one have? All versions easier for your Dad I should think, almost unstallable if diesel.
Hope youll still drop by here from time to time..
Clau, perhaps heaters already being enabled is not so unlikely, as they are last in the queue for electricity and you had to fit the pins in the socket there isnt really a penalty for pcm. Let's hope so!
Purple, is this going in your new car? Looking forward to hearing how it went um when u have time etc...headlamp bulbs...but this is so much more interesting.....I still have the ex-MB van eber i bought when i had my first galaxy. Replaced car with higher spec one that already had the heater fitted, never got round to fixing it... so i've still not had neighbours telling me car's on fire...
Edited by oldbod, 27 January 2015 - 05:49 AM.
The other replies you've had or will get are from people who know a lot more about this stuff than I do.  Treat what I post as something along the lines of intending to prompt "it won't be that, but I wonder if"  thoughts rather than informed advice. I know I do - treat my own thoughts that way I mean.
#62 clau_logo
clau_logo
  • 180 posts
  • Vehicle Driven:MondeoMk4 EcoBoost
  • Name:Claudiu
Posted 27 January 2015 - 06:29 AM
Oldbod, the ids showed that everything is ok, no faults and no errors. There was only 2 failed positions: i don't have electric heated rear seats and i don't have automatic transmision. And everything else was ok. In this morning worked ok. 0 degrees and in 2 km started to get warmer. So i suppose it is ok. Just have to check the relays with the clamp meter and it will be done. ;)
Drive safely, girls prefer you in one piece!
#63 oldbod
oldbod
  • 5525 posts
  • Name:Alan Severne
Posted 27 January 2015 - 07:13 AM
Thanks Clau. Glad it's working for you. Those clamp meters are great arent they, much quicker to use. But if you're getting heat after 1.5 km in your climate guess that's the important thing. :-).
Quick look your temperatures today about the same as where i am. Have to see if my car arms up in that distance. Btw - do you have a working egr or is it blanked?
Edited by oldbod, 27 January 2015 - 07:27 AM.
#64 clau_logo
clau_logo
  • 180 posts
  • Name:Claudiu
Posted 27 January 2015 - 10:39 AM
The Egr is working, i didn't blank it.
#65 somervillearron
somervillearron
    TF regular
  • 910 posts
  • Vehicle Driven:mondeo mk4
  • Name:arron somerville
Posted 30 January 2015 - 09:13 AM
i am actually having trouble getting this passat its a 1.9
have a look at my other post its large but i could do with some advice!
but yeah my mondeo heats up in less than 5 minutes total when driving! can be as much as 8 minutes it depends on how its being driven
2002 MONDEO MK3 LX TDDI 115PS
2008 MONDEO MK4 ZETEC 1.8 TDCI  125PS
just bought a few weeks back.
currently having electrical issues
also issues with my brakes feeling very spongy all of a sudden!
#66 clau_logo
clau_logo
  • 180 posts
  • Name:Claudiu
Posted 17 February 2015 - 08:54 PM
So it's done. Tested the heater with the elm327 and forscan. Work like a charm and no programing needed.
Sorry that it took me so long to respond but i had some problems: first of all, a guy smash my rear bumper of my car and then i had some oil engine leaks. I will post some pictures this weekend. Cheers! ;)
#67 kikiu93
kikiu93
  • 3 posts
  • Vehicle Driven:Mondeo mk3 2.2 TDCI
  • Name:kiril slavov
Posted 24 September 2020 - 01:26 PM
Hi,
Can you make the guide as you told a few times.
I am interested in retrofitting auxiliary heater to my mondeo.
#68 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28556 posts
Posted 25 September 2020 - 12:48 AM
Are you asking about the electric heater that uses 3 glowplugs or the diesel
fired heater?
#69 kikiu93
kikiu93
  • 3 posts
  • Name:kiril slavov
Posted 26 September 2020 - 01:38 PM
Actually i am interested in both to retrofit
But this topic is for heater with 3 glowplugs.
If you can share some guides for both it will be best.
#70 kikiu93
kikiu93
  • 3 posts
  • Name:kiril slavov
Posted 04 October 2020 - 05:55 PM
Hello,
Can someone share part number for glowplugs.
I find everything i need to retrofit aux heater, but i would like to change glowplugs before i put it.
I see that current glowplugs are Beru Germany ,but can't find the same one, even if i write part number which is on thw glowplugs
