Direction control not working - Air-Con / Heating (Mk1/Mk2 Mondeo) - TalkFord.com
4 replies to this topic
#1 Mega Mondeo
Mega Mondeo
  • 107 posts
  • Vehicle Driven:Mk2 Ghia Estate
Posted 27 June 2014 - 01:00 AM
Hello
First off just to let you know I have done my research on here and elsewhere.
My direction control only goes to the windscreen (default) setting. I have had the controls out and have tried an new control switch which didn't make a difference. I have cleaned out the T junction, no difference.
I have manually moved the lever on top of the vacuum unit and it does change the direction, but when I remove the pressure it goes back to default.
Is there a good way to test the tubing for leaks? or could the Vacuum unit be faulty? I can pick up another unit cheaply, so may do this just in case. Any help would be great.
P.S the fan speed control was also only working on high, but after some fiddling with all the vacuum hoses it seems to have started working again, is this related to the direction problem?
#2 cozmium
cozmium
    Always busy with something...
  • 234 posts
  • Vehicle Driven:Mondy Mk1 Ghia X 4x4
Posted 28 June 2014 - 10:48 AM
Is there a tube on the back of the direction control that has vacuum? (you should be able to hear it sucking an feel it with your finger on it).
If so, it sounds like the actuator (the silver grenade shaped thing) has a bad diaphragm - they can and do fail after time, though i'd be tempted to rig up a hose from the vacuum line directly to it to make sure.
#3 nigelrrb
nigelrrb
    Getting on a bit...
  • 142 posts
  • Vehicle Driven:Mk2 2.0 GLX Estate
  • Name:Nigel
Posted 28 June 2014 - 01:44 PM
The fan only working on max speed sounds like the resistor unit has failed - speeds 1, 2 and 3 all go through the resistor pack but speed 4 bypasses it. It is located in the left front footwell, more info here:
http://www.mirez.co.uk/HeaterPack.htm
#4 siruncle
  • 18998 posts
Posted 28 June 2014 - 08:29 PM
there's a few topics with regards disassembling the car to get at the vacuum pipes behind the dash, some of it you can see with just the glovebox removed.
click back to the aircon forum ( http://www.talkford....-mk1mk2-mondeo/ ) then change SEARCH in the search box to "this forum" and type "heater vacuum" in the search box then hit enter.
#5 Mega Mondeo
Mega Mondeo
  • 107 posts
Posted 29 June 2014 - 06:00 AM
The speed control was faulty. I could air hissing from inside it. I hooked up the vacuum connector to another unit and it worked. But now the speed only works full speed again, looking at the wires going into the resistor unit they look like it needs a new one. That will be next weekends job.
