Adjusting The Handbrake Adjuster - Suspension / Wheels / Brakes / Steering (Mk1/Mk2 Mondeo) - TalkFord.com
7 replies to this topic
#1 Chrissssss
Chrissssss
  • 64 posts
Posted 29 October 2012 - 05:50 PM
I've seen plenty of posts about the handbrake on these cars going slack and there being no way to adjust the adjuster but when I was having a fiddle before my MOT last year I just happened to find a way to reset the adjuster so the handbrake only travels a few clicks like it should.
I've done it on my 1.8 Zetec and my grandfather's 2.0 Ghia (a little more difficult with the different center console) and it was a simple job. Hopefully I can describe it well enough so people can do it. It does't last forever but should last many months or a year.
You need access to the adjuster mechanism (on my car simply remove the tray and the coin slots so you can view it). Lift the handbrake, shove a screwdriver between two points that lock the adjuster in place, push the handbrake down, put it all back together. It was alittle more awkward on the automatic ghia, had to remove a bit of the console to get to it but easy enough.
I've attached a picture to show where I put the screwdriver too.
  • ChrisMcBard likes this
#2 sgking
sgking
    ST200 Limited Ghia X
  • 6505 posts
  • Vehicle Driven:car
Posted 03 November 2012 - 09:32 PM
nice one.
Mondeo 2000 ST24
Mondeo ST200 Limited Edition no 181/300 'Ghia X'
#3 dave21031963
dave21031963
  • 15 posts
  • Vehicle Driven:Mondeo si 16v
Posted 18 November 2012 - 03:11 PM
sounds a daft question but do you leave the screw driver in?
#4 Chuck buckles
Chuck buckles
    Advanced Member
  • 39 posts
  • Vehicle Driven:Mondeo Mk1
  • Name:Dave
Posted 14 September 2015 - 08:55 AM
I had a go at doing this over the weekend. The adjuster resets but when I release the handbrake it pops the adjuster cam back to its current position, where the handbrake has more travel than it should.
So instead of 4 clicks it had 6 or 7. It holds the car ok and there is more travel still in the adjuster.
Wondering if I should slacken it off and release the handbrake adjusters at the drums before resetting the handbrake and trying again to reduce the travel.
It's not a great issue but I'd rather know if the handbrake adjuster is worn now and needs replacing bridge the mot in Jan when it's too cold.
Anyone know if the handbrake can fail for too much travel even if it holds the car fine?
#5 mondy zetecs
mondy zetecs
    Clever Clauggs
  • 4157 posts
  • Name:Harry
Posted 14 September 2015 - 09:11 AM
Depends on the MOT tester my mk3 handbrake came right up loose after new rear calipers fitted, didn't get time/weather/ to tighten the cable a few turns but held the rear wheels and got a advisory on MOT and passed.
Fiesta 1.0 ecoboost 2014
#6 Chuck buckles
Chuck buckles
    Advanced Member
  • 39 posts
  • Name:Dave
Posted 24 February 2016 - 10:17 PM
Update on my handbrake issue. Thought the cable was stretched and was about to replace it. When I looked at the rear drums the handbrake cable had popped off its mounting point so think it was then only working on one side.
  • siruncle likes this
#7 ChrisMcBard
ChrisMcBard
  • 16 posts
  • Vehicle Driven:MK1 Ford Ranger XLT
  • Name:Chris McBard
Posted 17 January 2021 - 07:01 PM
Thank you!!
Garage trying to charge me £150 to adjust the parking brake. They do it to me every MOT and only adjust it a tiny amount. I'm gonna take it in this time rock solid.
#8 ChrisMcBard
ChrisMcBard
  • 16 posts
  • Name:Chris McBard
Posted 18 January 2021 - 02:16 PM
Nevermind, didn't work for me in a mk2 auto LX. Different handbrake rachet by the look of it.
There are also no adjusters in my drum brakes so I guess I'm going to put my life in the hands of 4 axle stands =[
Edited by ChrisMcBard, 18 January 2021 - 02:17 PM.
