Some Questions About Ford Fiesta Freestyle (2002) - Ford Fiesta Mk1 / Mk2 / Mk3 Forum - (1976-1995) - TalkFord.com
8 replies to this topic
#1 CoachWalkerR
CoachWalkerR
  • 9 posts
  • Vehicle Driven:Fiesta Freestyle
  • Name:Robert Walker
Posted 07 June 2012 - 05:55 PM
I have a Ford Fiesta freestyle 5 door hatchback 1242 CC (12/7/2002) petrol. (UK mark V)
When they say replace the "air filter" is that the same as replace the "induction air filter"
Is a "crankcase emission filter pad" applicable to this car?
Is the petrol fuel filter external to the fuel tank?
Thank You
Robert
#2 siruncle
  • 18998 posts
Posted 07 June 2012 - 06:17 PM
petrol fuel filter is usually externally mounted under the car not far from the tank, although i can't say its definite location, mine on the mondy is under the car, under the rear seat area.
if you have an induction kit, the crankcase emission filter pad is probably not there anymore, and the rocker cover has either a baby filter on it, or its piped into the induction tube/hoses, if you still have a standard airbox, its the foam bit inside the airbox in a little "pocket" you can sometimes wash it out, or if you wanted either buy new, or chop a chunk of a green backed foam kitchen scourer, and use that,
aftermarket induction kits filters are usually lifetime, as are the replacement airbox elements also available, and might occasionally need a blowout, with compressed air, (airline at garage?) some like k&n have a special lubricant you can add.
#3 CoachWalkerR
CoachWalkerR
  • 9 posts
Posted 07 June 2012 - 08:40 PM
Extremely grateful for your response. Thank you
I have 2 instructions on my service schedule one is "replace the air filter" and the other is "replace the induction air filter". Is this the same thing?
#4 siruncle
  • 18998 posts
Posted 07 June 2012 - 08:50 PM
Hover over the pics, they are "standard engine bay" (standard air filter needed) and "induction kit" (typical cone filter on an induction kit, blow out with compressed air occasionally)
Choose which looks like your engine bay (they may not be identical, but similar looking)
Note: Induction kits are available to fit your car, k&n do one for it http://www.ebay.co.u...=item5adf52b567 as well as other manufacturers, they also do a replacement element that will fit in a standard airbox, http://www.ebay.co.u...7#ht_1396wt_905
Induction kits will produce a nice roar, even on little engines when you put your foot down, the element will not make as much noise but you might get a little, they cost a bit more than normal filters, but universal fit ones are also available only sometimes you might need to improvise a bit to fit it.
This is just the box standard filter http://www.ebay.co.u...#ht_1373wt_1037
#5 CoachWalkerR
CoachWalkerR
  • 9 posts
Posted 07 June 2012 - 08:52 PM
Thank You
#6 siruncle
  • 18998 posts
Posted 07 June 2012 - 09:44 PM
No problems mate, you sorted out whats under the bonnet filter wise?
mine has a cone, gives a lovely roar, if you boot it a bit, especially in enclosed spaces/on the high st etc... :naughty:
#7 CoachWalkerR
CoachWalkerR
  • 9 posts
Posted 07 June 2012 - 09:46 PM
I'll have to look under the bonnet. I think it's possibly the normal setup. In either case it's either or, not both right?
#8 siruncle
  • 18998 posts
Posted 07 June 2012 - 09:56 PM
yep, :L
only need one source of air as its a fiesta, not bugatti veyron.
  • CoachWalkerR likes this
#9 Dura-cil
Dura-cil
  • 20 posts
  • Vehicle Driven:Mondeo mk3
  • Name:James
Posted 09 June 2012 - 11:46 PM
lol ^^^
