Heater temperature control cable - Air-Con / Heating (Mk1/Mk2 Mondeo) - TalkFord.com
14 replies to this topic
#1 Antithesis
Antithesis
    Turned out nice again
  • 217 posts
  • Vehicle Driven:Mondeo
  • Name:Terry
Posted 12 April 2012 - 10:03 PM
Hello,
I'm about to tackle replacing the heater temperature control cable. First snag is that the manual says remove the radio. Do you need special radio removal clips or is there another way?
Thanks for any help.
Mondeo, MK1, 1.8i, LX, Hatchback, Nouveau red, first registered 22/10/93, bought by me 09/02/94
#2 siruncle
  • 18998 posts
Posted 13 April 2012 - 08:19 PM
4x 4" nails, anything that will fit in the holes and hold the locking tabs in place, on the left of pic is proper removal tool on right is allen key and drill bit, can use knitting needles, stick welding electrodes, needs to be pretty straight, stiff, and about 2-3mm diameter.
to remove, push in till they click on tabs, squeeze the removal kit left two together, and right two together, then both sides outwards and pull the radio outwards of the dash, you might need to wiggle it a bit but they come out, if one side sticks it is the removal kit not engaging the clips properly. :L
#3 stevedohc16v
stevedohc16v
    MEG Commander
  • 6006 posts
  • Vehicle Driven:Many Fords!
Posted 14 April 2012 - 07:05 AM
Hello,
Are you changing the cable because of difficulty switching between hot and cold and the knob just springs back? The cable will just be kinked and can be straightened out rather than replaced, plus the root of the problem is a sticky selector lever in the drivers footwell so a new cable may just kink again.
Steve
53 Ink Blue Mondeo ST220 estate
08 Tonic Blue S-Max Titanium
And my other toys are:
1994 Radiant Red Ford Escort RS2000 4x4
1987 Diamond White Ford Capri 2.8i special
#4 Antithesis
Antithesis
  • 217 posts
  • Name:Terry
Posted 14 April 2012 - 09:14 AM
Thanks Pete. I found them on ebay for about £1 posted so bought some. I'll follow your instructions.
Thanks Steve, yes the cable springs back and it's always on cold. I've already bought a new cable from Ford now. I read about the lever sticking and already sprayed some WD40 around it but I'm not sure how loose it's meant to be. It takes a bit of force; you couldn't move it easily with one finger for instance. Without comparing with a known good one it's hard to know I suppose.
#5 stevedohc16v
stevedohc16v
    MEG Commander
  • 6006 posts
Posted 14 April 2012 - 10:11 AM
Aye theres very little you can do about the stiff lever as its the internals that you need to lubricate and that would of course mean stripping the whole heater unit down. The way round it is (once you have fitted your new cable) to just operate the temperature dial very slowly when going to hot, twisting it quickly against the stiff lever is what causes the cable to kink.
Steve
#6 Antithesis
Antithesis
  • 217 posts
  • Name:Terry
Posted 14 April 2012 - 10:32 PM
Thanks Steve, I'll see how it goes. Don't fancy taking the whole thing out, sounds like a lot of work.
#7 Antithesis
Antithesis
  • 217 posts
  • Name:Terry
Posted 17 April 2012 - 06:11 PM
I have the dash apart and have removed the old cable, but comparing with the new one, it has a different 'clamp' on the lever end. Pictures (well, scans) will make it easier to explain:
This is the old one:
This is the new one:
The old one goes over the cable and clips onto something near the lever (it's hard to see what as my touch bulb went) I suppose I'll have to use some pliers to try and break the new one off, may need a hacksaw. Unless anyone tells me otherwise. There's always a snag isn't there?
#8 siruncle
  • 18998 posts
Posted 17 April 2012 - 06:16 PM
the new one doesn't clip into somewhere on the unit, close to where the old one did? it might be a revised part, retrofitted to the existing guts?
#9 Antithesis
Antithesis
  • 217 posts
  • Name:Terry
Posted 17 April 2012 - 06:23 PM
Hello Pete, I don't think so because when the temp is on cold the two plastic parts are close to each other similar to the pic of the new one above. The plastic 'clamp' doesn't slide on the cable to move it to a different position it's fixed so can only go where the old one went... if you see what I mean. Really annoying.
#10 Antithesis
Antithesis
  • 217 posts
  • Name:Terry
Posted 17 April 2012 - 06:44 PM
Found a small torch, went and had another look armed with a screwdriver. Managed to pull this out:
I see what they've done now. Where the old one used two separate bits of plastic that clipped together, the new one is just one molded piece. Too dark now to continue will have to finish it tomorrow. At least I know it's the right cable anyway. Thanks again.
