headlight adjusting motor always on - Ford Fiesta Mk1 / Mk2 / Mk3 Forum - (1976-1995) - TalkFord.com
headlight levelling freestyle fiesta mk3
3 replies to this topic
#1 CoachWalkerR
CoachWalkerR
  • 9 posts
  • Vehicle Driven:Fiesta Freestyle
  • Name:Robert Walker
Posted 05 March 2012 - 10:40 AM
When my headlights are on there is a constant whirring from the offside headlight adjusting motor. The whirring noise changes slightly when I adjust the headlight levelling control but it doesn't stop. Any suggestions apart from replacing the unit?
#2 siruncle
  • 18998 posts
Posted 05 March 2012 - 08:22 PM
pop the switch out and disconnect it that should temporarily disable it. sounds like an electrical fault somewhere along the line...
#3 Maximos_wales
Maximos_wales
  • 5 posts
  • Vehicle Driven:Fiesta 1.8TD DI
  • Name:Richard Hammond
Posted 06 March 2012 - 03:48 AM
I got this problem also. I've not investigated it fully but when I lower and raise the beem it doesnt move on the side that's werlling.y guess is the gears in the motor are not catching properly. I'm going to take mine apart and see if it's worn or just loose. I think you should do the same.
I have a 2001 fiesta btw.
#4 siruncle
  • 18998 posts
Posted 06 March 2012 - 10:03 PM
if the mondy of that era is anything to go by the motors are pretty much pull off push on, and can be found at scrappy's, ebay etc... :L
Also tagged with one or more of these keywords: headlight, levelling, freestyle, fiesta mk3
