Mine appears to be the same, is there a guide anywhere to do this please?
tombchasser has posted in What do you really dislike about the Mk5 Mondeo? in Mondeo Mk5 General Discussions.
Today, 03:12 PM
mondy zetecs has posted in Waaaaa brake pedal hit the floor at 60mph 😂 in Suspension / Wheels / Brakes / Steering (Mk3 Mondeo).
Today, 02:20 PM
twincarbs has posted in Stiff gear selection (1st & 2nd) first thing. ST TDCI in Transmission / Drivetrain (Mondeo Mk3).
Today, 01:51 PM
mondy zetecs has posted in Stiff gear selection (1st & 2nd) first thing. ST TDCI in Transmission / Drivetrain (Mondeo Mk3).
Today, 01:10 PM
PURPLE_2L_LX has posted in buttons_of_console_awhful_view in In-Car Entertainment (Mk4 Mondeo).
Today, 01:05 PM
PURPLE_2L_LX has posted in Stiff gear selection (1st & 2nd) first thing. ST TDCI in Transmission / Drivetrain (Mondeo Mk3).
Today, 12:55 PM
Today, 12:34 PM
Fan settings - all blow air at the windscreen
Started by
Chronos-X
, Aug 20 2011 06:29 PM
14 replies to this topic
#11
Posted 07 November 2013 - 08:13 AM
#12
Posted 07 November 2013 - 10:49 AM
I'm assuming the EATC doesn't have vacuum pipes to direct air flow, as it's all done electronically?
I had RB2004 come to me to check it, he replaced with another control panel and it didn't seem to fix it.. so it can't be the panel sadly.
Has anyone seen or heard from him on here recently?
Lee
2001 Ford Mondeo 2.0 Ghia X
Stardust Silver
#13
Posted 07 November 2013 - 08:51 PM
Not sure if there's aguide, but from memory it's fairly straight forward, a Haynes manual may be of help to locate fixings.
From memory (so I may have missed a step) it's something like this:
Remove the radio - make sure you have the code
Remove the single screw on either side of the radio aperture - the screws are about an inch from the front if the panel and halfway up the height of the radio hole.
Remove the ashtray & cigar lighter & remove the screws.
Pop the caps off & remove the screws that secure the sides of the centre console.
Remove the screws from the bottom of the armrest CD/Cassette holder cubby hole and slide the centre console back a few millimeters - you don't need to move if far, just enough to access the screws on the bottom of the radio fascia panel which you need to remove.
Pull the knobs off the heater controls, they may be tight on the spindles but unless a previous owner has glued them on they *will* pull off.
If you have heated seats or TC switches below the radio push the switches out from behind, and disconnect the wiring plugs.
Gently pull the plastic panel forward, the top is held by spring clips and will pop out of their locations.
If you have electric mirrors disconnect the plug from the rear of the adjuster switch
Undo the screws holding the heater control pane and ease it forward.
Disconnect the temperature control wiring plug, and the illumination wiring plug.
Unclip the vacuum pipes from the back of the other two controls - they use the same "clip" method as the electrical connectors, you can't confuse them when you reassemble as the plugs are all different.
As Haynes say, re-assembly is the reverse of removal.
If it has t*ts or tyres .... It's gonna cost you!!
#14
Posted 08 November 2013 - 01:08 AM
Slight correction to the above step....
The screws on the bottom of the radio fascia are the two screws bhind the ashtray & cigar lighter and will have already been removed, I should have said move the centre console back just far enough to be able to remove the radio fascia panel
Edited by Exeter Mondeo Man, 08 November 2013 - 01:09 AM.
#15
Posted 23 October 2014 - 05:40 PM
Ok so I am a few years late to the party. I now have two MK2 Mondeo's. One 1.8 and one 2.0. Both had exactly the same problem. As described above I removed the controls and I stripped the one that sets the fan speed. Both of them has the little part described in an earlier post missing. They were never there. The lube to lube them is still sitting there untouched. Why no previous owner bothered to have it fixed I do not know.
Well what I did was I took a piece of pipe and bridged the vacuum pipes plugged into this switch. The black pipe to a white pipe. Center pipe is re-circulate (fan switch to the left)and outer is fresh air position(fan switch to the right)
At least this way all the setting works.
You should first check if the vacuum pipe attached to the inlet manifold is attached before taking your car apart.
