Common problems with the Mk3 V6? - V6 'Duratec' Petrol Engines (Mondeo Mk3) - TalkFord.com
26 replies to this topic
#1 Nick
Nick
    The Bloke In Charge
  • Webmaster
  • 25825 posts
Posted 11 March 2011 - 02:38 AM
I'm updating the Mondeo Mk3 Buyers Guide, and am researching common problems. Are there any with the Mk3 V6? I can't think of any off the top of my head. What about things to look for if purchasing a V6?
Interested in finding out what all the crypto currency fuss is about and why so many people are making thousands of pounds?
TalkCrypto.co.uk
#2 The Guv.
The Guv.
    DRIVEN...
  • 4122 posts
  • Vehicle Driven:BMW 530D & 2x ST220s
  • Name:James
Posted 11 March 2011 - 01:39 PM
Only things I can think of are the idle control valve which makes the 'moosing noise' and the idle tensioner which can rattle on idle... but both would be pretty apparent in any case.
Other than that, no common things to watch out for on these really, service history is key when buying one, main dealer is an advantage because then you've got a good chance they changed all 6 sparks. But then again, service history goes with out saying.
I could rebuild a Mondeo from the ground up with my eyes closed... that's thanks to owning a TDCI.
#3 Jugs
Jugs
  • 15 posts
  • Vehicle Driven:Mondeo zetec S v6
  • Name:Carl.
Posted 17 March 2011 - 10:36 PM
Hi I'm new to this sight after found it after trying to research problems with the 2.5 v6 zetec S Mondeo. I have just brought a 51 plate which drove very nice. After about one week it started cutting out when idle in traffic, then took about 6 attempts to start. After a few days the warning light came on so I got a mate to do the relevant checks. The result being error code P0320.
Today a garage replaced the crank sensor and I thought all was fine untill about 3 hours later the car cut out again when idle in traffic. This happened twice and the engine light came on but started on the first try. The light then went out on each occasion and was fine on the short journey home. Should I start worrying or getting more work done? My knowledge is pretty basic and usually rely on main dealers who hit the pocket tho!
Apologies if I have put this question in across someone else's. Any advice is appreciated.
  • Davec74 likes this
#4 Mark24v
Mark24v
  • 748 posts
  • Vehicle Driven:02 Mondeo V6 Zetec S
Posted 25 March 2011 - 07:27 PM
Front wheel bearings and broken springs but i suppose all models suffer from these faults.
2002 Mondeo Zetec S 2.5 V6
2004 MR2 Roadster+ hardtop+chrome style/roll bar 30000 miles.
1995 Ford Probe 16v
1998 Toyota Rav4 Freesport AWD (daily driver)
#5 Jugs
Jugs
  • 15 posts
  • Name:Carl.
Posted 31 March 2011 - 05:19 PM
Hi I've ended up replacing leads, plugs and coil pack. Apparently very common problem. Aftermarket coil packs not meant to be much cop!
#6 The Guv.
The Guv.
    DRIVEN...
  • 4122 posts
  • Name:James
Posted 31 March 2011 - 07:48 PM
Not so sure it's a common issue on the v6 mate. Is on the 1.8 and 2.0 but not the v6. The coil packs and ht leads exceed 100k easily in my experience.
#7 pcs333
pcs333
  • 61 posts
  • Vehicle Driven:MK3 Ghia X 2.5ltr V6
Posted 25 April 2011 - 08:30 PM
Is the weak head gasket not a common problem on the mk3`s like the mk1 & 2s?
Seems very common on the earlier engines, perhaps ford rectified the problem on mk3`s. Can anyone claryfy this?
#8 kelvinterry
kelvinterry
  • 498 posts
  • Vehicle Driven:Mondeo mk3 2.5 GHIAX
Posted 25 April 2011 - 09:29 PM
not really it wa all mainly the plastic water pump impeller on the mk1/2 that caused the problem.
I'm a petrol head
04 Mondeo Ghia x 2.5 v6 vroom vroom not broom broom.
Defender + horse when in the Andes Peru,
Worked with diesel cars and trucks for over 40yrs no intentions of owning one for pleasure
previous 1999 mk2 2.0 Ghia x 1998 mk2 2.0 1998 mk2 1.8 estate. In the days when I had money 1990 BMW 7 series, 1960s alfa Romeo Spider boat tail, When I was a boy racer 1960/70s Escort RS turbo, Mk1 Lotus cortina, E type. More motor bikes than most people have had hot dinners?
#9 pcs333
pcs333
  • 61 posts
Posted 26 April 2011 - 07:25 PM
Cheers for that, I was led to believe it was a weak head gasket. :rolleyes:
#10 PRC Ghost Rider
PRC Ghost Rider
    The Mad Kiwi
  • 3849 posts
  • Vehicle Driven:JDM Mk3 Mondeo ST220
  • Name:Brick Top
Posted 03 May 2011 - 08:18 AM
Has the bottom end issues been sorted out? Better rod bolts and big end bearings?
  • Carsrecoverycambridge likes this
Proud owner of a 2005 Mondeo ST220. Big upgrade from the tired old 1997 ST24, which went out in a blaze of glory fighting off Hondas and BMWs
If its got tits or tyres, it'll give you trouble......
Have you ever noticed? Anyone going slower than you is an idiot, and anyone going faster than you is a moron
