Mk3 preface console removal + Double din fitting (pic heavy!!) - In-Car Entertainment (Mk3 Mondeo) - TalkFord.com
52 replies to this topic
#1 Ben_W
Ben_W
    6 cylinders.....its the future ;)
  • Forum Moderator
  • 3828 posts
  • Vehicle Driven:Insignia
Posted 16 July 2009 - 11:31 AM
MODS: Can someone make this a sticky again after the other one got deleted???
The following is a bit of a guide on how to remove a prefacelift centre console. I have also included how I fitted my double din HU as too many people say it cant be done in a preface motor. Oh yes it can!!!
Tools required:
Radio removal keys
Phillips screwdriver
Dremel type tool
Masking tape
String
Start by removing the head unit. Release keys in either side will release it, pull it out, make a note of what connections are what (there are on a factory head unit, power, aerial, speakers and remote stalk), disconnect and remove headunit. Will look like this…
Secondly, remove your gearknob. On a preface they have a lift up reverse which is spring loaded. As the gearknob comes undone, lift off carefully as the spring is still under tension. Store knob and spring somewhere safe. You don’t need to remove the lift up collar.
Next, remove the centre console side trim panels. There is a screw in the footwell end. The other end is just clipped in
Next remove the gearstick gaiter and surround. Its located by some small yellow pins and just pulls out with a little care.
The top of the gaiter has an elasticated collar, so will just pull over the lift up collar to enable complete removal. Should be looking something like this now
Next step is to remove the switches from the centre console. You should be able to reach down behind them and push them out of the console from behind. Before removing the connectors, I used masking tape to label them so I didn’t get mixed up (There will be the boot release, heated screens and hazard and airag telltale and depending on model, ESP & heated seats). The cupholder WILL NOT come out. Its screwed to the console from behind so that’s stays attached until the console is out.
Again, store all switches safely. Now its time to remove the screws. There are 2 inside where the radio was, one either side
There are 2 either side of the centre console
And the most awkward 2 are tucked right up under the bottom of the console
There are also two further up the console, one behind the hazards switch and one behind the heated screens switch
http://i222.photobuc...77/DSCN0631.jpg
Once this lot is removed, its time for the centre console to start coming out. I found it easiest to start working from the bottom up, for reasons that will become apparent. The console is held in by some fairly meaty clips at the top and at this point, the clock and climate/aircon bits are still connected. The framework around the gearstick is quite flexible and will push down to allow you to pull the bottom of the console panel forward, over it
http://i222.photobuc...77/DSCN0637.jpg
You might find it helpful to loosen the whole of the centre console. 3 8mm bolts in the armrest storage
http://i222.photobuc...77/DSCN0633.jpg
and a screw under the cig light bit
http://i222.photobuc...77/DSCN0636.jpg
Once that’s done, you should now have enough room to get in behind the panel and disconnect the elctrical connections to the aircon unit and clock. The aircon bit has one of those funny folding clamp affir type connections. That had me stumped for a couple of mins! Once they are disconnected, its time to be brave! As mentioned, The console is held in by some fairly meaty clips at the top. These are the buggers…
http://i222.photobuc...77/DSCN0638.jpg
To release the centre console, its needs a fairly strong pull in a forward and downward direction (diagonally down toward the gearknob is probably a good description) to release them. You wont break them, just be careful. Once they are out, carefully remove the console, watching and being careful of the still attached cupholder at the bottom. You should now have you centre console out. Well done. Time for a brew and a biscuit.
If you are fitting a double din hu, remove the cupholder and aircon unit and clock (all just screwed on)
I fitted an Alpine IVA-W202Ri to mine. In comparison, you can see it’s a big bigger, not much though.
http://i222.photobuc...77/DSCN0647.jpg
Get the cage for your h/u and measure where you need to cut on the black plastic within the radio cutout on the console. I used a dremel type tool with a cutting blade. It will need trimming. I found it easiest to take it down to the bottom edge as it’s a bit awkward to cut in this area (you’ll see what I mean if you try)
There is a flap of plastic that separates the H/U and the aircon unit which I neded to cut to allow the cage to fit properly
http://i222.photobuc...77/DSCN0640.jpg
Cut small amounts at a time and keep checking. Eventually the cage will fit. Mine looked like this
http://i222.photobuc...77/DSCN0641.jpg
http://i222.photobuc...77/DSCN0642.jpg
Once fitted and your happy with it, use the locking tabs on the cage to lock it into place
http://i222.photobuc...77/DSCN0644.jpg
http://i222.photobuc...77/DSCN0645.jpg
Time for another brew and another biscuit!
Once you are happy, refit the clock, aircon unit and cupholder to the console. Before refitting the console, I tied lengths of string round all the swith connectors and threaded the bits of string through the appropriate holes on the console (only did it for the upper switches as it was a complete pain trying to get them when I put the console back on first time! This method means you just pull the bit of string and the connectors appear! Before clipping the colse back in, reconnect the clock and aircon connections. Push the clips back in at the top and guide the cupholder back in at the bottom. Refit everything else. Should now look like this….
http://i222.photobuc...77/DSCN0646.jpg
Sort the wiring out for your new head unit, connect and test. When happy, fit your head unit. Be tidy with the wiring as there isnt too much room behind there.
Enjoy you double din H/U!!
http://i222.photobuc...77/DSCN0648.jpg
Some work will probably be needed to make it look neat round the edged. The trim that came with mine wouldn’t fit when I had the H/U mounted at the depth it is. Several people on here have built custom surrounds to make it look neater. The Guv did a good one, some pics can be seen here
Hope this helps guys. Any questions, get in touch!!
  • Ford Survivor likes this
Stardust Silver Mondeo Zetec-S Saloon - Lower than a depressed racing snake.....sold, gone but not forgotten
Hatch for show, Saloon for a pro.......
Buggy, buggy, buggy!
#2 slabsdidst
slabsdidst
  • 370 posts
  • Vehicle Driven:2006 ST TDCI in PB
Posted 19 August 2009 - 01:28 PM
Great thread mate, cheers for taking the time to take pics and explain this. I have a preface mk3 and have just bought the centre console from a facelift ghia along with the sony 6 cd changer and am going to have to cut into the dash to allow the outer gearstick trim to fit. Its really useful knowing just how to remove the console.
2006 ST TDCI in performance blue. Full leather recaro seats, remap, GW decat, mirrors with courtesy lights, xenon 8000k HID, LED side lights, somehow - mint original ST alloys??
97' Honda CBR 600F for playing with!
Past mondeos: 2001 black mondeo ghia, 2.0 tddi with remap to 150bhp
#3 Ben_W
Ben_W
  • Forum Moderator
  • 3828 posts
Posted 19 August 2009 - 10:35 PM
Its going to be more than just cutting in the panel.
The fan/aircon unit will need rewiring and the wiring for the stereo will need the connectors changing i think. Its a lot of work getting a facelift console into a preface.
#4 The Guv.
The Guv.
    DRIVEN...
  • 4122 posts
  • Vehicle Driven:BMW 530D & 2x ST220s
  • Name:James
Posted 20 August 2009 - 09:05 AM
Bit pointless going though all of that to only end up with a bog standard sony/ford headunit :S
They ain't all that lol.
And yeah they're completely different connections, you'll need to get hold of a quadlock loom, also you'll have no way of securing the headunit as the newer headunits have 4 locking points which need to clip in to a specially designed frame which you'll only get with a facelift console.
I could rebuild a Mondeo from the ground up with my eyes closed... that's thanks to owning a TDCI.
#5
  • Validating
  • 1 posts
Posted 20 August 2009 - 09:52 AM
Ben, do u have any photos with changing preface to facelift console?
Do it need completed rewiring or just make some wires longer/shorter?
Any more troubles with replacing?
May be someone has links to articles with howtos about it?
#6 Ben_W
Ben_W
  • Forum Moderator
  • 3828 posts
Posted 20 August 2009 - 10:08 AM
Jagy, i have not done the preface to facelift console change.
There are one or two on here that have, but its a big big job. A guy on here with the user name L11XXY will be able to tell you best, think hes done the whole thing
#7 paulwhite1987
paulwhite1987
  • 1784 posts
  • Vehicle Driven:Mondeo MK3 Zetec
  • Name:Paul
Posted 03 September 2009 - 09:02 AM
hi, im looking at getting a double din and like how this is done above. does the surround cover the existing recess of the old unit to look neat and tidy. pics if poss.
Currently driving: 2011 Ford S-Max Titanium TDCI (163)
Previous car: 2003 mk3 Pepper Red Mondeo Zetec
-STAFFORDSHIRE MEMBERS SIGN UP HERE-
#8 Ben_W
Ben_W
  • Forum Moderator
  • 3828 posts
Posted 03 September 2009 - 09:54 AM
Because i have my headunit set deep, i cant use the trim ring that came with it. There are no kits available for the preface so the only way round it is to custom build one. Not got round to this yet.
#9 Ben_W
Ben_W
  • Forum Moderator
  • 3828 posts
Posted 25 October 2009 - 02:13 PM
Finally got round to modifing the trim ring to fit. Still not perfect but MUCH better than before. Needed some plastic from the bottom and some ribs from the top and 2 sides dremelling out.
#10 The Guv.
The Guv.
    DRIVEN...
  • 4122 posts
  • Name:James
Posted 25 October 2009 - 06:10 PM
Have you decided against getting it done at plush?
