Carracer12 has posted in Mk7 Alarm keeps going off after battery replacement in Ford Fiesta Mk7 Forum - (2008-2017).
Today, 04:33 PM
PURPLE_2L_LX has posted in DPF Delete - Recommendations Please! in Diesel Engines (Mk4 Mondeo).
Today, 03:52 PM
rickb8585 has started DPF Delete - Recommendations Please! in Diesel Engines (Mk4 Mondeo).
Today, 01:34 PM
Today, 12:55 PM
PURPLE_2L_LX has posted in 2009 2.0 tdci titanium x auto in Drivetrain (Mk4 Mondeo).
Today, 11:21 AM
P0353 code and misfire
Started by
Pete1
, Nov 29 2008 08:53 PM
No replies to this topic
#1
Posted 29 November 2008 - 08:53 PM
Has anyone experienced this error ?
P0353 Ignition Coil “C†Primary/Secondary Circuit
My car started and ran fine, the next time I started it it wouldn`t start, left it for about 5-6 hours and it started ut with a terrible misfire. I had a spare set of leads so replaced them and the misfire is still there (leaving the car undriveable). The plugs where also changed about 3,500 miles ago.
When I ran diagnostics from my Scanguage it came up ith the above error.
I am wondering if this is an internal coil pack error and the coil pack needs replacing or an external error eg. coil earth strap etc.
Modified ST24, Mk3 V6 ZetecS, ST220.
#2
Posted 29 November 2008 - 08:58 PM
knackered coil pack.
[color:blue]Pre facelift[02 plate] Mk3 1.8 LX petrol in oyster sliver, colour coded door/bumper strips,lexus rear lights,more mods in the pipeline.......[/color]
#3
Posted 29 November 2008 - 09:01 PM
i would say the coil pack has had it, try reconnecting the big multiplug on the front of the coil pack to see if it cures it or make sure the leads are on it and in the correct order, but if all of these checks are fine and u still have that missfire, then get a new coil pack, if u get it from www.fordpartsuk.com trevor should sort you out with a cheaper one then your local fords, i wouldnt get a second hand one in case its no good, its one item i would deff recomend getting new, its about 49 pounds delivered if im correct but it sorted out my missfire i had, hope this helps
98 Ford Mondeo/Contour v6
my st24 turbo progress
my garage
Dont fcuk with this St24
Shudda bRought a Scooby
my garage
#4
Posted 29 November 2008 - 09:23 PM
Thabks for your advice, Im almost certain the leads where changed correctly but are there any diagrams to check this unfortunatly I dont have a haynes manual ?
#5
Posted 29 November 2008 - 09:44 PM
no problems buddy, on your coil pack u should have the numbers on there to indicate where each plug lead goes hope this helps
my garage
my garage
#6
Posted 29 November 2008 - 09:58 PM
Thats great, 1 more question !! do you know what the cylinder numbers are ?
#7
Posted 29 November 2008 - 10:01 PM
ill have a look for u right now buddy and ill post them on here
i know the one at the rear left goes 1 but ill get back to u right now
my garage
my garage
#8
Posted 29 November 2008 - 10:10 PM
ok just got back from looking under the hood of my car, if u are standing in front of your car looking at your engine like ive said the leads are numbered as this:
rear bank left to right = 1 2 3
front bank left to right = 4 5 6
hope this helps
hope this helps
my garage
my garage
#9
Posted 29 November 2008 - 10:30 PM
Thank you for your help much appreciated, I will let you know how I get on.
#10
Posted 30 November 2008 - 05:50 AM
Found this on google a while ago, any use to you????
Good luck in getting it sorted!!!
"The object of war is not to die for the good of your country but to make the other bas*ards die for theirs!!"
Juice Green "P Reg" Mk2 Mondeo 2.5 V6 Si Hatchback - GONE BUT NOT FORGOTTEN
JOIN --------"ONE OF THE BEST" if not "THE BEST" mondeo websites going!!!!
