Follow this to fix it and how to prevent it happening again
1, Jack car up take off the Driver's side (off-side) wheel. You can do the job without taking the wheel off but its more of a struggle
2, Un-clip wheel arch cowling from bottom upwards to about half way up so you can get your hand/arm in to get to your washer bottle.
3, You will see the end of your washer pipe (where its come off) and the nozzel on the bottom of the water bottle, if you try to put it back on you will find that you may have to stretch the pipe for it to fit back on. Do not stretch it as this will only come back off after a short time later with the force of the water.
4, Open bonnet. Look down to find the water pipes held in with clips. Un-clip them, go back under your car and give the end of your water pipe a bit of a pull, that way you have some slack to fit back on the the water tank nozzel and you will find it easier to push back on
5, To be more secure and prevent it happening again, buy some small cable ties (ty-wraps). Once you have fitted the water pipe back on the nozzel put a cable tie round the pipe aswell over the nozzel, this should secure the pipe for not comming back off.
6, Re-fit the arch liner and put the wheel back on, ensuring the wheel-nuts are torqued up correctly on
