Heater not working - Air-Con / Heating (Mk1/Mk2 Mondeo) - TalkFord.com
Heater not working
17 replies to this topic
#1
  • Validating
  • 9 posts
Posted 14 October 2008 - 04:58 PM
Hi, the heater in my mondeo has decided to stop working. It blows in cold no problem at all. The dial goes round from cold to hot without a problem, and all 4 fan strengths work. Any ideas where to start? :)
#2 52graphite
52graphite
    Still tinkering
  • 4620 posts
Posted 14 October 2008 - 05:04 PM
Thermostat packed up?
Was it a sudden failure? Is there any difference at all between hot and cold?
my name is Mark.
2004 C-MAX Ghia 1.6 TDCi || A JLR vehicle of some description
Gone but not forgotten: 2002 Mk3 1.8 Graphite in Magnum Grey on LPG ¦ Garage entry
Haynes manuals at Amazon: Mondeo Mk1 diesel ¦ Mk1/2 petrol ¦ Mk3 pre-face/facelift | C-MAX
#3
  • Validating
  • 9 posts
Posted 14 October 2008 - 05:12 PM
It was on cold all summer, then I was out the other evening and it got a bit chilly so I turned it round about half way, it was a bit sluggish and did stick, I'm afraid I just pushed thru the resistance, I suspect I broke it!! And no, there's no difference at all between hot and cold.
#4 stevedohc16v
stevedohc16v
    MEG Commander
  • 6006 posts
Posted 14 October 2008 - 07:22 PM
The hot/ cold flap siezes up on the side of the heater unit (up in the drivers footwell) does the hot/ cold knob spring back round when you try to set it to hot? the cable usually kinks causing this.
Steve
53 Ink Blue Mondeo ST220 estate
08 Tonic Blue S-Max Titanium
And my other toys are:
1994 Radiant Red Ford Escort RS2000 4x4
1987 Diamond White Ford Capri 2.8i special
#5
  • Validating
  • 6 posts
Posted 16 October 2008 - 10:50 AM
Where does the cable run? Also is there any way of just removing the single panel with the knobs in it?
Any help would be much appreciated. I dont want to have to start wearing a balaclava in the car! :ph34r:
#6
  • Validating
  • 9 posts
Posted 28 October 2008 - 07:28 AM
Steve, the hot/cold knob did spring back initially until I forced it round to hot. Now it moves round between hot and cold quite freely but with no difference in temperature.
I've got a haynes manual but I'm at a loss to know where to start looking and I really can't afford to get a garage to look at it at the mo. I need to get it sorted, running 2 kids around in a cold car ain't fun!!
#7 rxt_ian
rxt_ian
  • 1225 posts
Posted 28 October 2008 - 05:11 PM
I think the lever that gets operated by the cable can be found on a bit of black plastic - look kinda to the left of the clutch pedal
Monty the 94 Mk1 [color:red][/color] Red [color:black][/color](Not pink anymore :banana: ) GLX 1.8 hatchback with 150K+ miles
#8 GJW
GJW
  • 182 posts
Posted 31 October 2008 - 05:22 AM
Hi. Does the fan blow out only on the windscreen?? if so have a failure in one of the vacuum lines. if these fail the vents default to windscreen. this can be tricky to find as a starter mine failed in the engine bay where the vacuum line was rubbing on a fuel line near the brake servo under the inlet manifold area. hope this helps
MK1 KA 2003... 2015 Fiesta Zetec S,  2008 Focus Zetec Estate....2014 Focus Titanium Navigator
#9
  • Validating
  • PipPip
  • 17 posts
Posted 06 November 2008 - 05:47 PM
This is Denny D. ( next prob to yours)Have you have a look at the help I had. Mine is now fixed.
Suggest. Can you feel the Knob pulling the cable or does it feel as if the cable has come off the end of the knob racket.You should feel some resistance. If not see what I did. Denny D My feet are now nice and warm !!
#10
  • Validating
  • 85 posts
Posted 07 November 2008 - 12:33 PM
Have you checked the pollen filter ???
My fans worked on all speeds but hardly any heat or air volume output
Knew right away mine was a pollen filter
Placed new one in, Got lovely hot air again
http://www.fordmonde...e_Pollen_Filter
Def
