Hi guys,
For whatever reason, the ECU/PCM is not giving the signal to the fan (via relay and fuse) but the fan goes when the A/C is on (as it should).
So What I'm planning to do is to install a separate fan controller which will trigger the fan.
To minimise messing about the existing wiring, I want to borrow the existing relay/fuse wiring and just tap the fan controller wire to existing trigger wire. Obviously I'll need to get the fuse/relay box out, flip it upside down to find and splice into the wire.
Any pointers?
Any pointers?
