Problem: In winter found heavy steering when parking on 10 year old 2005 StreetKa. The P/S fluid was at Max level but a very dark colour and the yellow reservoir cap had road dust around it. It may have gained moisture and was affected when temperature is near freezing outside in winter. The dark colour is due to debris. No sign of any leak but apparently air can leak in over the years.
Few hints about changing P/S fluid exist for Ka which has similar parts for Streetka.
Also Ford Spec per the Manual is an old spec and is expensive.
Solution: Carlube ATF-Q3 covers this and other specs and is inexpensive.
Required:
Carlube ATF-Q3 (ÂŁ10 / litre XTE100) - (Red coloured fluid) You need 1 to 2 litres to pump through.
Meat Baster (Wilko ÂŁ1)
Clear Plastic Tube 1.2 metres
Plastic Insert connector for plastic tube & Return Rear Hose
Wooden Dowel (or similar plastic blank to plug emptied reservoir hole - underneath only)
Old 2 litre bottle (to catch old fluid)
Pliers plus a Small temporary support for under Reservoir when it is lifted up 30 degrees
Required:
