Denso no sound no cd-changer no radio CDDJ Error - In-Car Entertainment (Mk3 Mondeo) - TalkFord.com
12 replies to this topic
#1 M82
M82
  • 6 posts
  • Vehicle Driven:Mondeo MK3 2.0 Ghia
  • Name:F.
Posted 01 October 2015 - 07:57 AM
Hello, since last week my denso sudentlly dont give sound and i cannot play cd-changer and mp3 in front unit. Navigation and Clima/Airco works fine/wel... I tried battery reset but i only get message CDDJ Error.. What could this mean? Fault in cd-changer? I add image how my nav screen now looks (from google but same, exept phone)..
Do I need maybe new head-unit or disconnecting cd-changer will help?  (apologies for bad english, i'm from Holland)
Edited by M82, 01 October 2015 - 07:58 AM.
#2 L11XXY
L11XXY
  • 3436 posts
  • Vehicle Driven:ST220
  • Name:Alex
Posted 01 October 2015 - 08:16 AM
The radio unit behind the touchscreen has stopped working for one of the reasons below
The communications chip is faulty
No Power to unit
Remove the touchscreen from the dash, unplug the large black connector, cycle the ignition twice, reconnect and try again
If it still doesnt work, you will need to replace the radio section of the headunit
Click the link for information
http://www.ebay.co.u...me=STRK:MESE:IT
Alex
02 ST220,Retro Fitted Touchscreen Nav,Bluetooth, Voice Control,Climate Seats, OEM DVD Entertainment, RSE System, Xenons, Focus Sub Lighting
Ford IDS Services available - Denso Touchscreen Sat Nav Repair & Diagnostics -
NOW WITH JAGUAR SDD DIAGNOSTICS ALSO
Bluetooth Diagnostics - Electrical Upgrades & Retrofits - Mobile Service may be available
Call Alex on the usual number
07955 406 446 - E Mail [email protected]
UPDATED 25th June 2020
#3 M82
M82
  • 6 posts
  • Name:F.
Posted 01 October 2015 - 01:02 PM
Thanks, I will try that, but need first to buy removal keys. If it not succeed, i'll have to replace only internal part of navigation? as in ebay link? and i get also radiocode and it will communicate with my cd-changer? i understand it has the lattest firmware so i'll be albe to use latest navigation disc (2012)?
#4 M82
M82
  • 6 posts
  • Name:F.
Posted 07 October 2015 - 03:09 PM
Hello Alex,
I've unplugged large black connector and it still doesnt work.. So i need to buy one radio-unit but the one in link you gave is expired? Can you pm? On ebay item says "Please note, these units will not work on cars fitted with factory fit Bluetooth / Voice control module" How can I find on my unit if its fitted with this or not?
While i was unplugging black connector, i may have unintendedly disconnected a red single wire... but it also may be laying there disconnected? if not, where do i need to put it in black connector and whats the function for this red wire?
Red wire
Back
Upside
Edited by M82, 07 October 2015 - 03:12 PM.
#5 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28313 posts
Posted 07 October 2015 - 08:31 PM
ETIS link below will give you your vehicle build details...
Use the vehicle tab and enter your reg or sometimes it needs the VIN
number. Main details on the right and at the bottom of that it says click
here for more info or something like that.
#6 M82
M82
  • 6 posts
  • Name:F.
Posted 08 October 2015 - 09:28 AM
Thanks for replay. I tried etis but found only information about equipment on car..
I think the red wire is just an ad-on for an extern device (or grounding) couse there is also other red vire (to see in picture) and this is also just wrapped around other vire..
this is from picture i just pulled nav from dash, red vire is clearly going to black radio connector but if its was only pulled in empty hole, or connected, i dont know..  i 'm sure alex would know,, but is still silent   :kaffeetrinker_2:
Edited by M82, 08 October 2015 - 09:29 AM.
#7 Andy Garrett
Andy Garrett
  • 1 posts
  • Vehicle Driven:Mondeo 2.5 Titanium
  • Name:Andy Garrett
Posted 12 August 2016 - 07:55 PM
No Power to unit
Alex
I just like to say a big thank-you to L11XXY. The advice you gave at the top of this page saved me a fortune on the vehicle I picked up this morning. £7.00 on some keys to get it out, a few hours over the last few days reading up on the problem and £150.00 knocked of the price I paid for the car (to be fair I was taking a chance). Once again thanks for the info and sharing your skill with the rest of us.
#8 kevthehairymonster
kevthehairymonster
  • 9 posts
Posted 17 July 2019 - 10:59 AM
My C Max is doing the same thing!
The radio doesn't put out any sound, the cd player didn't spin the disc up. And the aux input doesn't make any noise. Removed the unit and did the above test. Still no audio. The unit also doesn't let me change the time either.
I put it in diagnostic mode and it plays reference sounds through the speakers, but nothing else.
Where do I go next?
It also keeps forgetting I've given it the code, when I turn the ignition on I have to hold the am/FM button to override the code instruction, if I type the code it just sits there asking for the code.
Please help!!!!
#9 PURPLE_2L_LX
PURPLE_2L_LX
    Mk3 Forum Moderator
  • 28313 posts
Posted 18 July 2019 - 09:26 PM
Blown fuse, there are 2 fuses one is 24/7 live and the other is the ignition live
which gives it the 1 hour mode.
If you did the test as in post#2 then a new front end maybe required.
Start with the perm live fuse though if it forgets the code after turning teh ignition on.
If it only forgets after starting the engine then check the battery voltages...
battery/alternator test...  http://www.talkford....test-procedure/
  • kevthehairymonster likes this
#10 kevthehairymonster
kevthehairymonster
  • 9 posts
Posted 23 July 2019 - 11:30 AM
Hi, I did the above test.
The unit switches on without the ignition so it wasn't the fuse.
Anyone know where I can get a front end repair?
