Fuel vaporiser fuse - Diesel Engines (Mk4 Mondeo) - TalkFord.com
Fuel vaporiser fuse
21 replies to this topic
#1 oxenburger
oxenburger
  • 150 posts
  • Vehicle Driven:mondeo titatnium X
  • Name:JP
Posted 14 January 2014 - 11:03 AM
Hi all,
My car has thrown the p269f error a few times but both times I was on holidays in Ireland. And by the time i made it to a dealer the fault code was gone. Hasnt happened since and I was wondering where the fuel vaporizer fuse is as I want to check it.
Any information would be greatly appreciated
#2 mike4369
mike4369
  • 2983 posts
  • Vehicle Driven:2014 C Max 1.6TDCi
  • Name:Mike
Posted 14 January 2014 - 11:27 AM
I assume this is related to the DPF? Try F27 (30amp) and/or F32 (5amp) in the engine fuse box.
Edited by mike4369, 14 January 2014 - 11:28 AM.
#3 oxenburger
oxenburger
  • 150 posts
  • Name:JP
Posted 14 January 2014 - 11:58 AM
Thanks Mike. Good man
Sent from my GT-I9505 using TalkFord.com mobile app
#4 oxenburger
oxenburger
  • 150 posts
  • Name:JP
Posted 14 January 2014 - 01:43 PM
Checked the engine bay fuse box at lunchtime there and no fuses in either the F27 or F32.
This is the blurb on the tsb for it.
11/9/10 Engine malfunction warning lamp illuminated on the instrument cluster; Diagnostic Trouble Code (DTC) P269F present
63/2010 Should a customer express concern about the engine malfunction warning lamp illuminated on the instrument cluster, the probable cause is a blown fuse due to fuel vaporizer component internal short circuit caused by a fuel vaporizer overheating. The overheating is a result of a lack of fuel in the fuel vaporizer fuel line ahead of first Diesel Particulate Filter (DPF) regeneration.
Furthermore Diagnostic Trouble Code (DTC) P269F - Exhaust Aftertreatment Glow Plug Circuit/Open - is stored in the Powertrain Control Module (PCM).
To rectify this concern, a new fuel vaporizer system should be installed in reference to the instructions detailed in this bulletin.
For markets where FordEtis IDS is used, connect FordEtis IDS and select the appropriate symptoms from the concern descriptions above. Follow the FordEtis IDS instructions to rectify this concern and send any related diagnostic feedback session files. Failure to follow these instructions will affect any associated warranty claim submission. For markets where FordEtis IDS is not available, rectify this concern by following the attached service repair instruction.
#5 mike4369
mike4369
  • 2983 posts
  • Name:Mike
Posted 14 January 2014 - 03:58 PM
What's your next move?
#6 oxenburger
oxenburger
  • 150 posts
  • Name:JP
Posted 14 January 2014 - 04:42 PM
Not sure really. Hope it happens again before my warranty runs out I suppose and get it into a ford dealer asap.
#7 oxenburger
oxenburger
  • 150 posts
  • Name:JP
Posted 14 January 2014 - 08:22 PM
Apparently its the F9 fuse. Didnt have mu handbook at work today. Must check it out.
#8 hegacork
hegacork
  • 2 posts
  • Vehicle Driven:Mondeo Mk4 2.0tdci
  • Name:Mike Hegarty
Posted 16 June 2014 - 07:18 PM
Hi. Oxen burger,
How did you get on with changing the fuse?
I've a similar problem...ironically I'm in Ireland...could it be the weather? :-)
I brought it for diagnostics and the memory was clear as the message had disappeared.
Luckily, I was nearby my diagnostic pal when it appeared today and brought it straight to him.
It's the p269f scenario also.
What was your outcome? I disconnected and reconnected the electrical connector just in case it was loose.
Hope you got to the bottom of your problem...cheaply!!!
Cheer, Mike
#9 oxenburger
oxenburger
  • 150 posts
  • Name:JP
Posted 18 June 2014 - 12:47 AM
Hi Mike, it's stopped again. Only seems to happen every twenty thousand miles.
#10 hegacork
hegacork
  • 2 posts
  • Name:Mike Hegarty
Posted 18 June 2014 - 12:58 AM
Hi Oxen,
Did u actually change the fuse?..if so, where is it located?
Mike
