No Sound When Indicators On - Electrical (Mk3 Mondeo) - TalkFord.com
11 replies to this topic
#1 ballybrone
ballybrone
  • 15 posts
  • Vehicle Driven:mondeo
  • Name:Michael O'Reilly
Posted 21 October 2012 - 05:51 PM
My MK3 mondeo (2004 LX) recently has no clicking/ticking sound when the indicators are turned on.The indicators are working and the sound was working up till a month ago but not now.Is it something in the indicator stalk that makes the noise or is there a speaker or relay somewhere.
#2 siruncle
  • 18995 posts
Posted 21 October 2012 - 06:10 PM
click here: http://www.talkford....cal-mk3-mondeo/ and enter indicators not working in the search box on the page that loads, then click search, there's a fair few posts on inoperative indicators :L
No relays, apparently its built into the GEM
<p>From Rutland, Leicestershire or Northamptonshire? Join the Rutland Group, http://www.talkford....land-area-page/ Leicestershire, http://www.talkford....leicestershire/ or Northamptonshire, http://www.talkford....rthamptonshire/2000 (W) Mondeo Mk2 Ghia 2.0 Hatch in Stardust Silver, now has company, a 2000 (W) Transit Smiley :) 2.5di (ish), in diamond white, with a blue stripe. (pics coming soon). Also now got a
02 zetec-s 2.5 in Panther Black and an 05 Fiesta St150 in colorado red
This is Ford country, listen quietly and you can hear Vauxhalls rusting :)
#3 Brendan T
Brendan T
  • 11 posts
  • Vehicle Driven:Mondeo Mk3 LX
  • Name:Brendan
Posted 14 July 2013 - 05:56 PM
I have the same problem on my 2007 model.  as you will see I'm listed under the electrical section, so far I have had 102 read my question but no replies.  Have you made any progress. My fault is intermittent but mainly no sound.  On your I have read that the flasher unit plugs into the switch unit.  You need to remove the switch unit first which is fairly straight forward.
#4 Brendan T
Brendan T
  • 11 posts
  • Name:Brendan
Posted 15 July 2013 - 03:49 PM
Thanks for the reply; excuse my ignorance but what does GEM stand for?
#5 siruncle
  • 18995 posts
Posted 15 July 2013 - 07:48 PM
like an ecu, but for functions like wipers etc...
#6 ballybrone
ballybrone
  • 15 posts
Posted 11 April 2016 - 11:19 AM
Hi got a friend of mine to plug his laptop with diagnostic software to my car and on the GEM  we are getting a code B1875 - turn signal/hazard switch signal circuit failure.Also when we checked the chine it is set to off.
Not sure is this telling me that the indicator stalk is faulty or the gem module faulty.
The indicators actually come on its just the chime dosent work any more
#7 paul05149
paul05149
    Go On.....I'm All Ears...
  • 1941 posts
  • Vehicle Driven:Flapless 1.8 MKIII
Posted 11 April 2016 - 11:43 AM
This help?
http://workshop-manu...t_from_10-2005/
Paul m.
[URL=http://www.fuelly.com/car/ford/mondeo/2001/Texus/756013]
#8 paul05149
paul05149
  • 1941 posts
Posted 11 April 2016 - 03:59 PM
Quote from link above
"The sound generator for the acoustic turn signal check is integrated in the multifunction switch."
So I would swap out the indicator switch as a first option even though it's still working the indicators at present.
Paul m
#9 paul05149
paul05149
  • 1941 posts
Posted 12 April 2016 - 02:03 PM
Sound Deffo' comes from the switch itself.
Following is from workshop manual.
""Control functions
The following functions will be monitored by the GEM.
Interior lighting
The interior lighting will be switched on if:
one of the vehicle doors is opened and the ignition switch is in the OFF or ACC position
the ignition switch is moved from the ON or START to the ACC or OFF position
the vehicle is unlocked using the radio remote control
The lighting extinguishes
25 seconds after all doors are closed, but the vehicle is not locked
if the vehicle is locked
if the ignition switch is moved from the OFF or ACC to the ON or START position
The lighting is extinguished by gradual dimming over a period of 1.7 seconds.
Interior lighting consists of front and rear dome lamps and position lamps in the door inner trim.
Turn signals / hazard warning lamps
When the turn signal lever is actuated, the turn signal lamps on the corresponding side of the vehicle are activated at a frequency of 1.3 Hz (80 times per minute).
At the same time, a clicking noise is generated by the steering column switch and the turn signal warning lamp is activated.
If one of the turn signal lamps is defective, the flashing frequency is doubled, except in hazard warning mode.""
Cheers Paul m
Edited by paul05149, 12 April 2016 - 02:04 PM.
  • ballybrone likes this
#10 ballybrone
ballybrone
  • 15 posts
Posted 15 April 2016 - 03:57 PM
Thanks Paul M .
.Will try what you suggested, thanks for taking the time to investigate.Will reply how I get on.
