water leak - 1.6L to 2.0L Zetec Engines (Mk1/Mk2 Mondeo) - TalkFord.com
water leak
20 replies to this topic
#1 sjwagstaff
sjwagstaff
  • 339 posts
Posted 09 June 2011 - 05:31 PM
Just come to start the car and there was big water puddle underneath,looks like a leak from water pump.
Also temp gauge doesnt move at all ,stays in middle even when engine off and cooled down.
Any ideas ?
just a gasket for water pump?
car is a 2000 2.0 ghia x
cheers
#2 siruncle
  • 18980 posts
Posted 09 June 2011 - 06:07 PM
i'd top it up with water then run it and see if can see any leaks from hoses, then look at parts (pump, thermostat housing etc) if coming from pump area it could be knackered pump as when they go water comes out a little hole in the housing of the pump. it could also be from the metal pipe that runs under the engine below the bottom crankshaft pulley.
<p>From Rutland, Leicestershire or Northamptonshire? Join the Rutland Group, http://www.talkford....land-area-page/ Leicestershire, http://www.talkford....leicestershire/ or Northamptonshire, http://www.talkford....rthamptonshire/2000 (W) Mondeo Mk2 Ghia 2.0 Hatch in Stardust Silver, now has company, a 2000 (W) Transit Smiley :) 2.5di (ish), in diamond white, with a blue stripe. (pics coming soon). Also now got a
02 zetec-s 2.5 in Panther Black and an 05 Fiesta St150 in colorado red
This is Ford country, listen quietly and you can hear Vauxhalls rusting :)
#3 sjwagstaff
sjwagstaff
  • 339 posts
Posted 09 June 2011 - 06:57 PM
would faulty thermostat cause temp gauge needle to permanantly stay in centre position?
felt and water is coming from under water pump .
you got a picture of where water pump is on the 2000 2.0 ghia x
cheers
#4 siruncle
  • 18980 posts
Posted 09 June 2011 - 10:46 PM
if zetec i'm afraid, and pretty sure, its behind the cambelt cover, http://emeng.gentlyh...oling/Part2.htm (sorry is from westfield site but was 1st came across)
usually if thermostat fails if closed will overheat, if open will take ages to warm up. my 2.0 mk2 now up to running temp within about 3 miles (today). thermostats (if zetec) about £12 ish, if enclosed in plastic thingy you're prob looking at a lot more as its built into this plastic housing (one of reasons had another mk2) might be the temp sensor, again zetec one was £10.52 from ford, if same as mine, was held in by a clip on top of thermostat housing, in front of ignition coil. http://www.talkford...._1#entry1476412 have a look at my post, for finis code from ford.
#5 siruncle
  • 18980 posts
Posted 09 June 2011 - 10:50 PM
water pumps £30-45, i use eurocarparts.com site to get idea of prices of new stuff as can tap reg number in and it displays relevant stuff for your car.
#6 sjwagstaff
sjwagstaff
  • 339 posts
Posted 10 June 2011 - 12:35 AM
i think leak is coming from thermostat housing then ,easier fix? cheers for replies.
#7 siruncle
  • 18980 posts
Posted 10 June 2011 - 02:30 PM
when pop bonnet and look at engine it on right at end of cylinder head. think held on by 3 bolts, (zetec) i *think* you'll need a new gasket, to fit your replacement housing. my mk2 has a plastic housing maybe yours has too, if this the case when refitting don't go mad as you can crack it easily, i've read the silvertop ones not compatible as a hole slightly different and they're metal. if you only got 1 sensor in it you'll need the 1 sensor housing (have seen plastic with two) think probably a coil off job for access but it a pretty easy job otherwise. might be good idea to use torque wrench to tighten bolts up (if available). the sensor(s) should re-seal in new housing but if don't may need a bit of plumbing tape on threads (unless circlip type sensor as has rubber seal on it) if is a gasket make sore you clean both surfaces well.
#8 sjwagstaff
sjwagstaff
  • 339 posts
Posted 10 June 2011 - 05:34 PM
Thanks for all your help. wll just keep toppng water up until i sort new part.
#9 bigspj
bigspj
    Advanced Member
  • 46 posts
Posted 11 June 2011 - 02:06 PM
With regards to the temp gauge staying at half i thought this was normal. our 1998 1.8 verona does this. when you put the key in in the morning and turn it it goes down then.
#10 sjwagstaff
sjwagstaff
  • 339 posts
Posted 11 June 2011 - 09:43 PM
temp gauge is staying at half,even with key out and car left to cool down overnight...faulty sensor or normal?
