Are front doors interchangeable? - Interior / Exterior (Mk3 Mondeo) - TalkFord.com
3 replies to this topic
#1 blackestate
blackestate
  • 181 posts
  • Vehicle Driven:Mondeo 1.8 estate
  • Name:Neil
Posted 31 January 2011 - 01:18 PM
The passenger side front door on my facelift estate is going rusty across the bottom, I'm going to attack the rust and paint it in for now, but sooner or later another door would probably be the best long term solution. Does anyone know if the front door from a hatch/saloon is the same as that fitted to my estate. Also are the pre-facelift front doors the same?
Basically if all doors are the same I stand a lot better chance of finding a good panther black door if I can buy any mk3 front door safe in the knowledge that it'll fit.
Thanks.
1.8LX estate. Now with rear courtesy light, walnut dash & steering wheel, powerfold mirrors with puddle lights, front foglights, de-badged & full leather heated & cooled seats, retro-fitted electric rear windows, private plate, custom fit blinds, colour coded door handles, blackeyed headlamps, colour coded grill, Eibach springs, auto dimming rear view mirror.
#2 shane24v
shane24v
  • 173 posts
Posted 31 January 2011 - 03:49 PM
will be watching this for the answer as i need to replace my front and rear door on my estate.
#3 KAZUYADOG
KAZUYADOG
    I'm Bang Tidy
  • 9516 posts
  • Vehicle Driven:MONDEO 2.5T TIT X
  • Name:Mick
Posted 31 January 2011 - 04:12 PM
The front doors are all the same Hatch/Saloon/Estate,all you will find different are the trim levels on the inside.Some models
you will find with an attached door bump strip.
The rear doors Hatch and Saloon are the same.
The rear doors on the Estate only for the Estate.
MY ST220 ON THE DYNO AT DREAMSCIENCE DREAMSCIENCE DYNO WITH POWER OUPUT
2006 Final Facelift ST220 in Stardust Silver - Owner is a Fan Boy.
Now with its very first MOT.Second MOT passed today 6-July-2010.
19" Arden Sportline Alloys (German Jaguar) - 20" MS Design Alloys (For Shows)
This BOY - Is pure Chaka Chaka and Bang Tidy.
Dreamscience 251 bhp 215 lbf.ft - Bluefin Stg Two 241 bhp 211 lbf.ft
#4 compuwiz_uk
compuwiz_uk
    Global Mod
  • 19696 posts
  • Vehicle Driven:2001 1.8 Mk3 Mondeo
Posted 31 January 2011 - 06:10 PM
as per above, biggest problem you face is getting one with/without bump strips as per your requirements the rest of the differences between pre & post facelift models can simply be removed from the pre-face door & put in from your post-facelift door instead :L ( the differences would not stop the door fitting & working as it would fit & work spot on, just there is less wiring in the pre-face so you would loose puddle lights & powerfold if you have it now & other than that, the car would look wonky from the front as one mirror would be bigger than the other :} )
