Broken my lcd display on denso sat nav - In-Car Entertainment (Mk3 Mondeo) - TalkFord.com
17 replies to this topic
#1 toreg
toreg
    Newbie
  • 6 posts
Posted 10 January 2011 - 09:04 PM
Hello
Broke my lcd display on denso sat nav, do i need to bay a new unit?
#2 The Guv.
The Guv.
    DRIVEN...
  • 4122 posts
  • Vehicle Driven:BMW 530D & 2x ST220s
  • Name:James
Posted 10 January 2011 - 10:24 PM
Ford didn't make the screen, either dismantle and retrieve the make/model or get an electronics repair company to do the job.
Is the screen image ok? You may have just broken the touch panel itself which is a cheap fix.
I could rebuild a Mondeo from the ground up with my eyes closed... that's thanks to owning a TDCI.
#3 toreg
toreg
    Newbie
  • 6 posts
Posted 11 January 2011 - 06:12 PM
Hello
Thank you for the answere,looks like it`s the touch screen is broken.
how can I fix the screen?
glad I do not have to buy new device :)
#4 L11XXY
L11XXY
  • 3438 posts
  • Vehicle Driven:ST220
  • Name:Alex
Posted 11 January 2011 - 06:53 PM
You'll have a job to source the parts in this country...
The screens are made in Japan, i have the info somewhere. Your best bet is to wait for a screen to come up on Ebay if you have no luck sourcing one from the Net.
How did you break it?
Alex
02 ST220,Retro Fitted Touchscreen Nav,Bluetooth, Voice Control,Climate Seats, OEM DVD Entertainment, RSE System, Xenons, Focus Sub Lighting
Ford IDS Services available - Denso Touchscreen Sat Nav Repair & Diagnostics -
NOW WITH JAGUAR SDD DIAGNOSTICS ALSO
Bluetooth Diagnostics - Electrical Upgrades & Retrofits - Mobile Service may be available
Call Alex on the usual number
07955 406 446 - E Mail [email protected]
UPDATED 25th June 2020
#5 toreg
toreg
    Newbie
  • 6 posts
Posted 11 January 2011 - 07:06 PM
my wife threw the child seat in it :BEEP:
#6 The Guv.
The Guv.
    DRIVEN...
  • 4122 posts
  • Name:James
Posted 11 January 2011 - 10:07 PM
If you can find out the exact size and pin allocation of the ts you should be able to get hold of one easily enough.
Usually they're actually glass USB touchscreen panels so it doesn't make any difference who the manufacturer is when it comes to replacing. Or you could upgrade to a captive ts.
#7 L11XXY
L11XXY
  • 3438 posts
  • Name:Alex
Posted 11 January 2011 - 11:43 PM
The actual screen has a small flat ribbon cable for connection, not sure if thats any help at all.
I have an LCD screen in the loft, minus the touchpad section so i'll have a look at it.
If your touch panel is ok, i can always sell you the LCD.
#8 toreg
toreg
    Newbie
  • 6 posts
Posted 12 January 2011 - 06:56 PM
Hi
Its the touch screen that are damaged, lcd screen is ok
I'll try to take out the touch screen and find out what I need
does anyone have any tips how to pick out?
#9 L11XXY
L11XXY
  • 3438 posts
  • Name:Alex
Posted 13 January 2011 - 12:41 AM
Yeah... Very carefully!
Separate the screen from the rear circuit board ON the circuit board if that make sense.
There are several hidden screws also so have some good quality Torx screwdrivers handy.
#10 toreg
toreg
    Newbie
  • 6 posts
Posted 23 January 2011 - 01:41 PM
Hi
Then i had some time to take the panel out, i have searching internet after a new panel but it hard to find. anyone have a tips where to get a new one.
